Old June 17th, 2010, 07:36 AM   #1
randomwalk101
self wrencher
randomwalk101's Avatar
Gas tank
Bought a new gas tank but it does come with the key to open the gas cap. Is there anyway to remove the gas cap without the key? Taking the 8 screws should remove the entire assembly from the tank? Thanks all.
Posted via Mobile Device
Old June 17th, 2010, 07:45 AM   #2
2WheelGuy
2WheelGuy's Avatar
Unfortunately there is one screw that can only be removed with the cap open.
You can take the tank to a locksmith and get a key made. You can also break the lock using a dent puller or a drill.
AFM #278
Old June 17th, 2010, 09:20 AM   #3
randomwalk101
self wrencher
Thanks Craig. You're right. there is a single philip screw holding the assembley to the tank (along with the outside screws). I think this screw is for security (so peeps can't get into your tank by simple taking out the outter screws?). I guess I'll have to hit up the seller and beg for the key or (more than likely) plan B: the drill.
Old June 17th, 2010, 09:38 AM   #4
2WheelGuy
2WheelGuy's Avatar
If you drill it, don't drill all the way through. Go just deep enough to dig out all the tumblers. If you leave the bottom piece in tact you will have a racers gas cap that opens with a screw driver.
AFM #278
Old June 17th, 2010, 05:04 PM   #5
min nin
Motorcycle(s): 2007 250r
A locksmith could be the best answer. They might also be able to match the key to the ignition.
Last futzed with by min nin; June 17th, 2010 at 05:04 PM. Reason: ?
min nin is offline   Reply With Quote
Old June 17th, 2010, 06:42 PM   #6
randomwalk101
self wrencher
prob going to bust it and buy the slingshotracing's gas cap...silver cap on white fairing is going to be nice
Old June 18th, 2010, 03:52 PM   #7
randomwalk101
self wrencher
Okay looks like it's drill time. The seller doesn't have the key anymore.
So basically just drill down the middle where the key goes in? How big of a bit? Thanks
Old June 19th, 2010, 05:06 AM   #8
randomwalk101
self wrencher
Also anyone knows how to remove that fuel level sensor?
Old June 19th, 2010, 07:44 AM   #9
randomwalk101
self wrencher
Going to meet up a local rider who's a locksmith..he'll try to pick it. Woot!!
Old June 19th, 2010, 05:41 PM   #10
Banzai
Psychic war veteran
Banzai's Avatar
Motorcycle(s): Kawi Green '09 Ninja ZX6R
Pop off the plastic cover and remove the bolts. Getting the float arm out is a Cirque du Soleil event, but once you get it, it's cake.
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing!
Zodiac Mindwarp and the Love Reaction
Banzai is offline   Reply With Quote
Gas Tank Lock stuck? Maintenance for gas cap with pics! Skippii 1986 - 2007 Ninja 250R Tech Talk 35 May 6th, 2021 09:03 PM
