#1 |
self wrencher
New gen suspension upgrade
What are you guys running? What's best route to go?
Front: - racetech sprints / oil / gold valve emulator? - AK20? Rear: -penski -ohlins? Last futzed with by randomwalk101; July 7th, 2010 at 08:33 AM. |
#2 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
I dont have a problem with the stock stuff (im short n skinny) but weight has alot to do with it...how heavy are ya??
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
#3 |
The Sportisi Master
Race Tech .85 with Sling shot pre load adjusters 15w fork oil.
I don't waste time with the emulators but others do. The intimidators are good. Jean you know you want my shock. ![]() Guys have had issues with ohlins but the fastest guys are on them. Penske gets my vote until the new shock company that cannot be mentioned comes out with theirs.
Sportisimoto USA is born. |
#4 |
self wrencher
#5 |
The Sportisi Master
My 170lb guys are running .80 racetechs
#6 |
self wrencher
170 lbs but trying hard to go back down to 155. I'm 5,9" but I guess height doesn't matter in suspension.
Posted via Mobile Device |
#7 |
Join Date: Jun 2010 Motorcycle(s): 2008 ninja 250 Posts: 168
im 130lbs, 5'8" and Racing my bike. what fork oil and suspension upgrades would you recommend?
#8 | |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
After some time on the track can do more as your speeds increase.
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
#9 |
Ive been doing some quick laps at calabogie. through 18 im bottoming out my fromt suspension and its chattering. and im running a bridgestone bt? on the front and a metzler on the rear.
#10 |
Step 1: Get good tires
#11 |
My tires are good! brand new! plenty of grip
#12 |
Join Date: Jun 2010 Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000 Posts: 95
I installed the BT-003 RS tires. They super-rock.
#13 |
Join Date: Jun 2009 Motorcycle(s): 06 Ninja 650R, 08 Ninja 250R, 00 Aprilia SR50 (dead) Posts: 94
What's a slingshot preload adjuster?
#14 |
Okay, those Slingshot products look great. Glad someone finally made a KLEEN block-off plate too...
How do those Preload adjusters install if our fork caps are held in with c-clips? |
#15 |
self wrencher
Just bought a pair of Intiminator and going with 5w oil + stock spring as a starting point and go from there...(5w was recommended by Intiminator).
Thinking about SS preload adjuster but it doesn't fit stock handlebar. (had to go to 15mm-20mm preload)...might be too much?? any comment? |
#16 | |
self wrencher
#17 |
The Sportisi Master
Jordan yes they are held in with c clips. I just put a set on Bartlow's bike.
#18 |
The Sportisi Master
It's funny. I suggested an emissions block off plate like a month ago to them. Looks like Jim listens.
#19 |
Whats an intimidator? and emissions block off plate?
Colin #191 - Area P, Elka Shock, Woodcraft Clip-Ons and Rearsets, Attack Race Bodywork, BT 003RS, .700 Fork Springs, DynoJet Stage 2 and BMC High Flow Air Filter. 613 MOTORSPORTS.COM |
#20 |
oh and emulators?
#21 |
Block off plates are for helping with the
Emissions air injection removal. You only need one. Intimators are a drop in front suspension upgrade that proves front fork feel and help prevents the forks from bottoming out. |
#22 |
The Sportisi Master
Talked to spears and it sounds like ricor put the intimidators on the backburner. Colin unless your fast I wouldn't put emulators in the bike just yet.
#23 |
2010 250 Cup Champion
Join Date: Jan 2010 Motorcycle(s): 2008 Ninja 250R and 2007 Honda CR150F Posts: 168
I put the Elka rear shock on my bike along with .65 springs in the front and 15w oil. I'm light (~130), but am an experienced racer so for me, this combo works great.
#24 |
CVMA / AFM / M1GP #250
Join Date: Sep 2009 Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650 Posts: A lot.
Suspension upgrade | jgcable | 1986 - 2007 Ninja 250R Tech Talk | 13 | February 13th, 2015 02:22 AM |
Advice on Suspension Upgrade? | Sykes92 | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 20th, 2014 12:26 PM |
300 rear shock upgrade and front suspension | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 1 | January 22nd, 2014 12:07 PM |
Front suspension upgrade | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 4th, 2013 07:42 AM |
is this suspension upgrade possible???? | brausatch | 1986 - 2007 Ninja 250R Tech Talk | 5 | October 3rd, 2010 03:33 PM |
