#1 |
NEW 2013 Ninja 250r (2nd Edition)
![]() You think you might be looking at the Ninja 300? Think again, here it is, the new 2013 redesigned Ninja 250r. Available for purchase immediately for residents of Thailand. Engine Four-stroke two-cylinder water-cooled. Displacement: 249 cc. Valve system. DOHC, 8 valves. Cylinder size / stroke. 62.0 x 41.2 mm Compression ratio. 11.3:1. Transmission. 6 gears with oval turn. Ignition. Digital Fuel. Injection (∅ 28 mm x 2) with dual throttle. Starter. Electric starter. Body structure. Diamond steel pipe. Caster angle / Trail. 27 ° / 93 mm Tire size. 110/70-17 M / C (54S). Rear. 140/70-17 M / C (66S). Shock front. Shock pour les Copic size 37 mm Shock after Gas Shock single Tractor unit and arm adjustable 5 levels. Brake. Disk Brake Single 290 mm dual-piston calipers. Rear brakes. Disk Brake Single 220 mm dual-piston calipers. Length x width x height. 2010 mm x 715 mm x 1,110 mm Wheelbase. 1,400 mm Seat height. 785 mm Weight. 172 kg Capacity fuel tank. 17 liters. http://www.kawasaki.co.th/th/motorcy..._ninja250r.asp |
#2 |
Join Date: May 2013 Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F Posts: 125
theyre losing the ninja-style headlight...sadface
#3 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
The new kawi designs are fugly.
#4 |
I really like the new designs. I also like the older rounded soft look of 90-00s bikes like the 250r, zx6rr, etc. The new style is geometry with angles that have small soft edges. I like the new direction of style a lot. It looks more aggressive in more high-tech way to me.
But I respect your opinion. It may not be the look for some out there. 2013 636 is so hot! I want one but I know what I would do with it and nothing but trouble.... |
#5 |
I don't understand this thread. It is the same bike as the 300, but it comes with a destroked motor to take it back down to 249cc. Thailand, Japan, and a few other countries get this version instead of the 300, to better fit within tax and license categories. It was announced and released months before the 300 was released in the US.
/moved to 300 general discussion
#6 |
#7 |
#8 |
#9 |
Friendly Graffiti Artist
Join Date: Jun 2013 Motorcycle(s): 300 SE w/ ABS Posts: 28
#10 |
Que Buenos Son!!!
Join Date: Jun 2012 Motorcycle(s): Aprilia Shiver 750, Husaberg FE 450, Ninja 300 (sold), xr100 Posts: A lot.
MOTM - Nov '14
Can this thread please die.
Don't do something because it's easy,.. Do it because it's not! If you aren't going forward, then you're falling behind. ![]() ![]() |
![]() 0 out of 1 members found this post helpful. |
#11 |
Bass Master General
The engine capacity is the volume difference between the piston at the top of the stroke and the bottom of the stroke plus the gap at the top, if you were to make the stroke shorter in the same engine, you have a smaller engine capacity.
So yes, it has a 249cc engine, and yes it's the same engine as the 300 but they may have put a different crankshaft with a lesser diameter on and longer con rods. |
#12 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Wow kawasaki totally ripped off kawasaki to make the same bike just smaller
#13 | |
Ninja 250R Special Edition | beqwarrior | General Motorcycling Discussion | 3 | April 22nd, 2011 01:41 AM |
Ninja 250R Ice-Edition !!! | Stavrosqq | Pictures | 6 | February 11th, 2011 10:56 AM |
[topix.net] - Nation's Biggest & Much Awaited 2nd Edition of India Leadership Awards | Ninjette Newsbot | Motorcycling News | 0 | February 4th, 2011 10:50 AM |
