Old September 2nd, 2016, 11:38 AM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Exhaust pipe adapters/spacers/reducers?
So correct me if I'm wrong, but the outside diameter of the pregen header is 1-1/4". I'm looking at getting some shorty mufflers for mine, but the smallest diameters I can find are 1-1/2".
Auto parts stores are full of adapters, but nothing small enough to fit the 1-1/4" range. Anyone know where I can get adapters to make this work?
Cra1g is offline   Reply With Quote
Old September 2nd, 2016, 11:53 AM   #2
A piece of 1-1/4" ID x 1-1/2" OD aluminum tubing should work. Split it with a hacksaw so when you tighten the muffler clamp it squeezes the aluminum tube down to the 1-1/4" tube. Steel or stainless steel would work fine too, but they're a bit harder to cut and work with.
If you can't find it locally, McMaster-Carr should have it. You can take a look at their part number 9056K38. Other suppliers like Speedy Metals could probably sell you a piece too.
Old September 2nd, 2016, 12:20 PM   #3
Cra1g
Cra1g's Avatar
So something like this?
http://www.onlinemetals.com/merchant...946&top_cat=60
It's a 1.26" ID, which is pretty darn close. A one-foot section would cost $32
Old September 2nd, 2016, 12:54 PM   #4
That would probably work OK, but I don't know why you want to spend more than the McMaster piece costs.
Old September 2nd, 2016, 01:08 PM   #5
Cra1g
Cra1g's Avatar
Good point. The part you mention is only like $11 or so.
I'm also thinking about chopping the pipe right where the stock muffler finishes tapering off and mounting the shorties there. The OD at that point is around 1-3/8", but I think the mufflers would look good there. Only probably would be I wouldn't be able to resell the stock mufflers, since chopping it would ruin it mostly.
Not quite sure what I'm going to do yet. ¯\_(ツ)_/¯
Shortening a Yoshimura Carbon Exhaust Pipe TnNinjaGirl General Motorcycling Discussion 11 February 19th, 2015 06:26 AM
Need to know if this is bad for the Exhaust pipe and question of interest bloodline 2008 - 2012 Ninja 250R Tech Talk 17 February 11th, 2015 02:09 PM
WTB 88-07 exhaust header pipe quarterliter Items Wanted 4 December 4th, 2014 02:35 PM
Dressing up your Stock Exhaust Pipe! ScorpionNinja 2008 - 2012 Ninja 250R Farkles 8 August 24th, 2009 04:55 PM
