June 30th, 2014, 03:48 PM | #1 |
Mounting Camera Above Front Tire
I want to mount a (mostly) hidden camera on my bike and I was thinking that under the front fairing might be a good spot. How much clearance is there between the front fender and the under side of the front fairing if you bottom out the forks? Would there be room for an ION Air, ReplayXD, or Contour under there if the forks are bottomed?
June 30th, 2014, 03:57 PM | #2 |
I don't think there will be in the event you fully bottom out...
The biggest I would try for that is a 808 camera or their big brother the mobius. However, I think your going to want to re-think that placement. A) you need to get to it easier to verify it's on/recording and such... B) it will need constant power to record when bike is on... So wiring it up will need to be considered for your placement. Make sure the new wires won't interfere with the normal movement/space you have. I'd just put it on a suction cup mount on windscreen and call it a day.... |
June 30th, 2014, 04:04 PM | #3 |
Certified looney toon
MOTM Jul '13, Jul '14
Check out @allanoue's thread of mounting the 808 under the headlights
https://www.ninjette.org/forums/showthread.php?t=135939
June 30th, 2014, 04:08 PM | #4 |
Join Date: Dec 2013 Motorcycle(s): 2011 250R SE Posts: 326
NevadaWolf beat me to it.
That's the exact thread I was going to point you towards. The benefit of the mobius is that you can put it in dash cam mode where it starts recording when it gets power so you don't have to touch it at all. I'm pretty sure the 808 is the predecessor to the mobius. |
June 30th, 2014, 04:15 PM | #5 |
I want one that will record on power, and of the three I listed, only the Replay XD can do that for sure. I'll check out the 808 and Mobius too, thanks for the suggestions.
I'm not sure I want it on the windscreen, I like it clean...I'll think about other locations, maybe the headlights like that other thread you linked. |
June 30th, 2014, 04:24 PM | #6 | |
MOTM - Sep '14
June 30th, 2014, 04:31 PM | #7 |
Join Date: Mar 2014 Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R Posts: 256
Don't use the 808, get their newer model the Mobius action camera. Which is under $100 and very small. You can practically mount it anywhere. If you want to see the quality of the video here's a quick shoot I did this Sunday. Battery life is 1.5 hours and with external power it can shoot for hours.
June 30th, 2014, 04:43 PM | #8 | |
I'm toying with the idea of mounting the lens in the head light body where the little light that the US models don't have is ( I can't remember the name of light ). I just have to actually buy a camera to see if I can make it work. |
June 30th, 2014, 04:48 PM | #9 |
Right there...
June 30th, 2014, 04:58 PM | #10 |
That's be a cool spot if the view isn't blocked. That would also eliminate the whistling wind noise Mobius is notoriously known for. People have bought the Joovu case to help or tape up the mic openings. Also, one more thing you can't do is vlog since there's no external mic port. But for the price, it's a great deal and no worries if you lose it. I spent roughly around $700 on my GoPro with all the accessories and it got ran over by a car because their suction cup failed on me.
June 30th, 2014, 04:58 PM | #11 |
Yeah Mobius is the newer model to the 808. It hardware wise is the 808 w/ 1080p instead of 720p only.
The mobius does have extensions that would let you mount it there... However I would think the glare from lights would ruin it. Maye w/ HID's.... |
Mounting Contour Camera | Yakaru | General Motorcycling Discussion | 23 | January 3rd, 2013 11:45 AM |
Need some help with camera mounting | bkh2 | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 9th, 2012 01:12 AM |
Three Camera Mounting Failures... Help? | Jiggles | 2008 - 2012 Ninja 250R Farkles | 7 | August 15th, 2011 08:23 AM |
Mounting a camera? | Zombiphone | 2008 - 2012 Ninja 250R Farkles | 37 | May 27th, 2010 12:46 AM |
[motorcyclistonline] - MC Tested: Sportbikecam Camera-Mounting System | Ninjette Newsbot | Motorcycling News | 0 | June 19th, 2008 04:57 AM |
