October 15th, 2009, 07:14 PM | #1 |
Join Date: Jan 2009 Motorcycle(s): 09 Ninja 250 SE Posts: 106
Crackling Sound at 8-9K
So this is interesting. Ive been noticing it for awhile. At any gear higher than 3rd (4th or above) when i get to between 8 and 9K i hear a crackling sound from the engine...sounds like a metallic vibration i guess. after i pass 9K it doesn't do it and below 8K doesn't do it either.
anyone have any idea. freak thing or shud i take it in somewhere?
MnM 2009 ZX6r Monster - Vortex Frame Sliders 2009 Ninja 250r - (Sold ) |
October 15th, 2009, 07:14 PM | #2 |
sounds like marbles in a can being shaken around?
October 16th, 2009, 05:46 AM | #3 |
if i had to venture a wild guess then yea. its like a sharp metallic crackling sound just at those rpms at those gears.
October 16th, 2009, 09:52 AM | #4 |
first test- try using a higher octane fuel and see if the noise goes away.
if it does, you may be too lean in the clip position on your needle. you may need to add another washer if the higher octane test helps the pinging/denotation. Has the weather been extra hot there lately? |
October 16th, 2009, 10:20 PM | #5 |
eh not really that hot. im hoping i don't have to add another washer. its P.I.T.A for the carbs on the bike. idk how it is with u guys but two screws on both carbs are directly under the frame so you have to use an L shaped screwdriver, crazy
October 16th, 2009, 10:28 PM | #6 |
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250, '11 Street Triple R Posts: 337
Try holding your clutch lever during those revs.
At that exact same rev range, my clutch lever rattles. I wouldn't describe it as a crackling, so maybe not the same thing you're hearing, but it doesn't sound like a rattle--sounds like something loose inside the engine. But it's just the clutch lever. Let the sound start, then put touch the lever and see if it doesn't stop immediately.
The Sunday Best | Current mileage: 50,000 |
October 17th, 2009, 09:07 AM | #7 | |
Only $7! I couldn't find the Milwaukee Offset screwdriver that Vex loves so much anywhere locally, but found that at Sears. NJD022588 was here the other night and we had to do some unexpected carb work on his bike. He said that he likes this one even better than the MOS!
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders |
October 17th, 2009, 12:37 PM | #8 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250R Posts: 98
Hey Manoj..
Did this just start happening..?...try putting your snorkel back in (hard to get completely back in but you can shove it in pretty close if you pry on the grooved lips) and see what happens. I had 1 shim and the snorkel out on the VR6 and she ran perfectly...put the snorkel back in to "richen" it up and she crackled at 8-9 K and wouldn't pull beyond. Your case is different since you can go beyond 9K rpms but curious what resnorkeling does. |
October 17th, 2009, 12:46 PM | #9 | |
October 18th, 2009, 04:09 PM | #10 |
thanks for that link noche
and gamma i haven't installed the exhaust yet so not sure about that. and yea i do think its the clutch lever actually. ill check it again to be sure. and also after i install the exhaust
October 18th, 2009, 04:51 PM | #11 |
October 18th, 2009, 07:33 PM | #12 |
Tracking says she's in Phoenix .....tomorrow's the day !
October 18th, 2009, 07:37 PM | #13 |
ha i know can't wait. going to install it on tuesday i think
October 19th, 2009, 01:37 PM | #14 |
Surely there's gotta be a better DIY fix for the rattling clutch lever. Someone *nudge nudge* should come up with something...
October 19th, 2009, 02:29 PM | #15 |
There most likely is, but I would rather have a clutch lever that has the least amount of resistance as possible. Just seems adding nylon washers or whatever is needed to take out the loose lever would increase friction at that pivot point.
For me, it's a non issue due to me riding with my fingers on the lever. (Old dirt bike riding habit) |
October 20th, 2009, 06:10 AM | #16 |
Well i confirmed what you guys said. It definitely is the clutch lever. And i did notice how loose the clutch lever is in terms of play not only in and out but up and down as well. but i do agree with kkim in that it shouldn't be tight but i do think that there should be a simple solution to that. it is kind of annoying ha unless of course we do what kkim does
October 20th, 2009, 10:56 AM | #17 |
October 20th, 2009, 07:37 PM | #18 |
I think the rattling has to come from the up and down play, which if tightened shouldn't interfere with operation of the clutch, right?
October 20th, 2009, 07:40 PM | #19 |
thats what im trying to figure out. if anyone has tried tightening this will you let us know how the clutch runs after that. is there something that u CAN tighten for the up and down play? or is it just the in and out? hmmm
October 20th, 2009, 07:44 PM | #20 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250 (Blue!) Posts: 488
The only stock adjustment is the in-out play.
October 20th, 2009, 09:47 PM | #21 |
Which brings me back to my original point: Someone with a much better idea of what they're doing than me (like Kim) should figure this out for the better of all humanity.
October 20th, 2009, 10:30 PM | #22 |
Definitely. Go Kim!
October 20th, 2009, 10:44 PM | #23 | ||
I think he DID find a solution. :P |
October 21st, 2009, 05:02 PM | #24 |
Join Date: Jun 2009 Motorcycle(s): 2009 Ninja 250 (Blue) Posts: 167
I ride the same way, but for me the up/down play is a bit annoying - more so when the bike is at rest. Maybe I'm just fussy over fit and finish, and need to remind myself it's a ~$4,000 sportbike.
October 21st, 2009, 06:43 PM | #25 |
yea i know what u mean. at first when i noticed i thought, wait did something happen to my clutch lever, is something wrong. but then i realized okay its just how the lever is. does anyone know if the up and down play makes the clutch work easier?
June 21st, 2010, 12:54 AM | #26 |
i have the same exact probelm in liek 2nd and 3rd gear at around that rpm its liek a metal rattling noise in the engine and its only at that rpm, then as i ride out faster it goes away but it happens everytime..would that clutch lever problem make the noise happen in the engine cause it sounds liek its coming from below me..it sounds exact;y like this what u guys are describing and it rele annoying
June 21st, 2010, 01:05 AM | #27 |
put your hand on the clutch lever and see if it stops the noise. if it does, the problem is the clutch lever. if it doesn't, that's not what's making the noise.
August 3rd, 2012, 07:53 PM | #28 |
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja 250R - Kawi Green Posts: 138
I know this is old, but my clutch was pretty tight when I took it in to get tires insstalled. When I came back the mechanic said he loosened it because there needs to be some play for when the handles bars are turning, or something to that effect.
The first couple weeks I was riding I don't remember ever noticing this crackling sound, but then recently I hear it every time at ~8800rpm. I only have one bolt in my license plates because it's a Canadian plate on an American bracket, I thought it was that so I drilled a hole in the bracket for the other screw and put rubber between the bracket and plate. The rattling screw stopped but not the crackling.. After reading this page I remember it started around when I changed the tires and the mechanic loosened it... I will confirm tomorrow if holding the clutch works.. Hopefully! Thanks |
What is this sound? Is this what out-of-spec valves sound like? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 24 | November 15th, 2021 05:48 PM |
no sound | Ghostt | Help | 5 | March 7th, 2015 09:59 PM |
Name that sound | Vancouverite | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 31st, 2014 08:56 PM |
Does this sound right? | KawiKid860 | General Motorcycling Discussion | 10 | October 31st, 2011 05:51 AM |
does this sound right | reaperw | Videos | 10 | September 7th, 2011 11:48 AM |
