Old November 29th, 2021, 04:56 PM   #1
Vansaki
Motorcycle(s): 2007 Kawasaki 250
2007 Ninja 250 Brake Rotor Bolts
Does anyone know the correct bit size for the brake rotor bolts? Seems like its 8mm hex but I want to be 100 % sure before I screw one up. I want to paint my rims so I want to take off the rotors. I have an impact driver to do the job. Should I apply some heat before hand? Ive heard these bolts have red loctite on them ...
Thanks !
Vansaki is offline   Reply With Quote
Old November 29th, 2021, 09:54 PM   #2
Impact may strip bolts with too much speed. You want to use 6mm allen-key socket with 18" breaker-bar with slow & steady pressure. Use one hand to keep allen-key pressed into bolt. Make sure breaker-bar is 90-degrees to bolt axis while you apply pressure.
Pick up allen-key socket set from HF, you'll find other sizes useful too.
Old November 29th, 2021, 10:02 PM   #3
Vansaki
My impact driver... lol
Old November 29th, 2021, 10:21 PM   #4
Originally Posted by Vansaki View Post
Attachment 48500
Might work, don't really need that much impact force really. It's not corroded on or anything. You'll find red Loctite will give great resistance entire way. Will take long time 1/16th turn at a time.
Old November 29th, 2021, 10:27 PM   #5
Vansaki
Just gonna use impact driver to break them loose then use your method to remove them. When reinstalling the bolts is it necessary to use the red loctite ?
Old November 29th, 2021, 10:59 PM   #6
nah, there's enough Loctite remaining that it'll still grip pretty good. Be sure to use torque-wrench. It'll seriously feel like you're gonna snap that bolt before getting to proper torque.
Old November 30th, 2021, 06:17 AM   #7
Sometimes heat is necessary to get the Loctite to soften, and it always makes the job easier. I've never had to go above the temperature that makes spit on the end of my finger go "psss".
Front Brake, Rotor bolts rubbing, '07 250 gonzo 1986 - 2007 Ninja 250R Tech Talk 7 July 6th, 2014 01:57 PM
