January 27th, 2017, 07:35 AM | #1 |
2011 Ninja 250 throttle hesitation
i recently got a ninja 250 (first bike) got it for a decent price got it in winter so could not really ride it but went through all the gears checked the oil brakes etc everything looked fine also started it up and was running fine
now that the problem i am having is when i started it up before i put it in for storage i took it around the block 2-3 times and i noticed that when i get to the 5k rpm mark it bogs a little then suddenly gets lots of power and accelerates just fine after the 5k rpm mark i was thinking to when summer time comes around to change the oil and run seafoam through it hopefully that will clear up anything that is stuck in the carb? the bike is a 2011 ninja 250 with 8500km on it any help will be appreciated thanks and have a good day |
January 27th, 2017, 08:14 AM | #2 |
If you wait to work on it the problems will only get worse. At a minimum, drain the gas from the float bowls.
Changing the oil is always best before storage - not after. Sitting in a humid environment can cause internal corrosion if the oil is not fresh. I would fill the tank to the top, and add a fuel stabilizer for good measure. Most likely i would drain the tank in spring and fill with fresh gas to minimize the chances of bad gas causing running problems. Run the old gas in the mower or car - they don't care. Use ethanol-free 87 octane if it's available in you area, and add a strong fuel system cleaner like Techron Concentrate at 1oz per gal for a tank of 2. If the deposits in the carb are minimal it may do the trick, but it's possible the carbs may need to come off and be cleaned. If that's the case, come back and ask for advice before digging in - it will save you a lot of work and aggravation. |
January 27th, 2017, 08:58 AM | #3 | |
thanks for the help will let you know also i was thinking its still fairly a new bike with 8k km on the odometer will it actually need a carb cleaning i was thinking it might be just a foul spark plug so i tune up might do the trick? thats what i was just thinking not an expert or anything |
January 27th, 2017, 09:09 AM | #4 | |
One ugly son of a gun.
January 27th, 2017, 10:29 AM | #5 | |
If the oil looks OK, leaving it might be fine. If it looks like crude, I would change it now. Yes, a bike that new with low miles can need the carbs cleaned. I had a factory Honda tech tell me one of their new bikes was prepped and run, then sat in the warehouse for 4 months, and need the entire bank of carbs cleaned before it would start. Gas with ethanol goes bad quicker, and as gas evaporates in the floatbowls it leaves deposits that plug the jets. |
January 27th, 2017, 10:59 AM | #6 | |
ok thanks so much for the help i will empty the flotbowls as soon as possible |
January 27th, 2017, 12:48 PM | #7 |
MOTM - May '17
welcome hope you enjoy the experience.
Ninja 250 throttle issue | HerpDerp1919 | 1986 - 2007 Ninja 250R Tech Talk | 36 | June 25th, 2015 08:23 PM |
[twisted throttle] - Triumph Tiger 800XC 2011 - Twisted Throttle Demo Bike | Ninjette Newsbot | Motorcycling News | 0 | September 22nd, 2011 01:40 PM |
09 Ninja 250 Choke and Throttle ? | ozuhas | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 19th, 2009 11:09 AM |
hesitation? | kawi_cj | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 12th, 2009 07:00 PM |
