#1 |
Join Date: Mar 2012 Motorcycle(s): 2010 Ninja 250 -Blue Posts: 17
Biggest tire in stock swing arm
Hi everyone, I'm farely new to the bike scene, and decided on a ninjette. The issue I find is the rear wheel size, it seems a tad small (skinny) for my liking.
I'm hoping the community would help with some info on the largest size wheel and rims I could use on my ninja without having to do any modifications. And secondly, should I worry about the rear wheel losing traction on turns on the stock skinny wheels? As that is my main concern. And if I were to 2up on the ninja, should I invest in the larger wheel? Thanks in advance |
#2 |
If you don't inflate it, you could probably get a 240 in there if you pushed really hard.
#3 |
CBR250R Traitor
Join Date: Jun 2011 Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold) Posts: 924
Changing the tire size is a cosmetic only thing. You will have nice and large chicken strips.
http://www.ninjette.org/wiki/Should_...n_Larger_Tires |
#4 |
Ms. Personality
Pirelli Diablo Rosso Corsa II
140 rear, stock front. Problem solved. /thread |
#5 |
CBR250R Traitor
How does that 140 fit on the stock rim?
#6 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
No, just use the stock tire sizes; our selection of tires for the stock sizes is good.
There is no point to using a fatter tire (unless if you need race tires that you can't get at stock sizes).
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
#7 | |
Ms. Personality
Perfectly.
IE: Get the Pirelli Diablo Rosso Corsa II in a 140 rear and stock front. ![]() |
#8 |
Search. Function.
#9 |
Join Date: Dec 2011 Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L Posts: 142
It is not a function of too wide of a tire for the swingarm. Anything over a 150 is too wide for the rim and becomes dangerous because the edges pinch in. We run a 150/60/17 and it works well. worn to within 1/8" of the rear edge.
DO NOT use anything wider than a 160...
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles |
#10 |
hates stupid people
Are you wanting a bigger rear tire because of personal preference as you stated first? Or because you doubt Kawasaki's engineers and the bike's ability to perform on the tire size it was designed for, which you then said was your main concern.
My vlogging channel: Ma1iciousLogic |
#11 |
MOTM - Mar '13, Jun '14
Are you being serious?
#12 |
Swing arm | rodster | 2008 - 2012 Ninja 250R Farkles | 11 | February 10th, 2015 03:50 PM |
Newgen rear swing arm/tire and front forks. | 02337 | 1986 - 2007 Ninja 250R Tech Talk | 2 | January 19th, 2013 05:53 PM |
