October 12th, 2011, 10:36 AM | #1 |
Join Date: Aug 2011 Motorcycle(s): 2011 Ninja 250r SE Posts: 7
Lost instrument panel illumination
So on my way to work in the morning a few days ago and my bike starts to make a very load buzzing noise almost like an alarm going off Pretty sure it was a relay buzzing like mad then my fuel gauge illumination went out noise stopped a couple seconds later my speedo illumination went out. The next morning when i started it up to go to work my Tach illumination went out. So its in the shop at the moment getting checked out since i have warrenty. just wondering if anyone else has had this issue or if im just lucky.
October 12th, 2011, 11:06 AM | #2 |
Sounds kinda like an electrical short. I would think your display will be replaced. GL!
October 12th, 2011, 12:52 PM | #3 |
My speedo light goes out every now and then but is on most of the time.
October 12th, 2011, 01:31 PM | #4 |
just got off the phone with the dealer they said its just burned out bulbs? Seems kinda strange to me that all 3 would go out shortly after that buzzing noise and with only 3000km on the bike but hay what do i know lol. And im sure when i go pick it up and ask about they buzzing noise ill get some bullshit about its a normal sound for this bike to make.
October 12th, 2011, 05:35 PM | #5 |
Join Date: Apr 2011 Motorcycle(s): 1999 BMW K1200LT, 2001 Aprilia Falco, 2008 Ninja 250R and a whole slew of dirtbikes! Posts: 64
That doesn't sound right. I've had dash bulbs last 10+ years and 150K+ miles in cars before. Granted, they're a little more protected from the elements than they are on a bike, but I'd be suspicious if all 3 failed within a day of each other...especially with the buzzing noise. There's something that caused them to fail, a nicked wire shield or bad ground, something.
Those lights are on the same circuit as your tail light, so make sure your brake and tail light are working when you pick it up. Also, wouldn't hurt to see what size fuse is in the fuse block, make sure they didn't swap the 10A with a 15A or something to keep it from blowing the fuse. Best I can tell, there are only those three bulbs, the tail light and the two brake micro switches on that circuit, so the buzzing wouldn't have been coming from a relay, as there's not one on that circuit. It could be the ignition switch though as that's the switch that completes the circuit to power it. |
October 12th, 2011, 07:39 PM | #6 |
Had several dash/panel bulbs blow within a couple weeks on a new Hyundai Elantra 10 years ago. They said it wasn't covered under warranty until I said that they clearly weren't user-serviceable (cruise light, AC light, etc). They still refused to replace the ones in the stereo display backlight, which both failed on each side of the display within a few days leading to many years of frustrated night-time radio usage.
Anyway, they replaced what they were going to replace and they never blew again, but the story doesn't end there. A few years later we were out of warranty (over 100,000 miles) when the car started making a funny sound while my brother was driving it. He pulled over and discovered that it had NO oil in the engine! Yep: The oil light was blown as well and, with no indication that there was a catastrophic oil loss, he kept driving it until noises developed and the engine was damaged and required a full rebuild ($5,000). It had never come on when starting the car and we had no idea that it was supposed to, so we did not detect it. Because it was full synthetic, the loss wasn't immediately obvious until it had been driven plenty far enough to cause damage. It was a new car when the lamp had blown along with the rest in that unexplained event but there was no way to prove it so we had to suck it up and pay for the engine rebuild. The moral of the story is: FIND OUT WHY THEY BLEW IN THE FIRST PLACE AND HOLD THEM ACCOUNTABLE WHILE IT'S STILL UNDER WARRANTY! |
October 14th, 2011, 07:18 PM | #7 |
Thanks for the post guys. When i went to pick up the bike they told me that the wrong bulbs had been installed in the bike and that is what caused them to burn out so fast. Im not so sure i trust them. It would be nice to have the wiring diagram. Is there anyone online i have not been able to find one yet but i probaly was not looking in the right place's. Ya when the lights all went out i checked all other lights and functions on the bike because i was not sure what else was on that circuit and everything else was working.
Is blue illumination legal? | 2fidyswag | General Motorcycling Discussion | 10 | April 27th, 2013 01:02 PM |
LED instrument panel | akcalhoun | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 15th, 2012 07:27 AM |
Instrument Panel - Rattle | Clearlynotstefan | 1986 - 2007 Ninja 250R Tech Talk | 11 | May 16th, 2011 03:13 PM |
