November 25th, 2011, 08:14 PM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R Posts: 131
Aftermarket engine plugs?
Does anyone know where I can get some aftermarket engine plugs that will be easier to drill for safety wire? The plugs I'm referring to are the ones that look like you could turn with a large washer or coin. There are 2 such plugs on the alternator cover. Yosh makes some plugs, but they don't specifically mention ones for the Ninja 250.
November 25th, 2011, 11:06 PM | #2 |
L8APEX
Join Date: Nov 2011 Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org! Posts: 233
I tried cross checking the ninja plug part numbers to see where else they may have been used by Kawasaki and came up with only the EX500 for which there are no fancy plugs. But the oil fill cap on the 250 is also used on the KLX 110 so there are plenty of blingy caps out for those.
www.joemillersmoderngarage.com www.starr-cycle.com ***The most important concept of science isn't memorizing facts, it's observation of phenomena.*** |
November 26th, 2011, 01:10 AM | #3 |
CMRA Mini Endurance #6
Join Date: Mar 2011 Motorcycle(s): CBR954, CBR600RR, EX250 Posts: 108
CMRA lets us silicone those plugs, not wired.
November 26th, 2011, 07:26 AM | #4 | |
UPDATE: I came up empty handed Last futzed with by samw; November 28th, 2011 at 09:34 PM. |
December 25th, 2011, 07:42 PM | #5 |
Join Date: Dec 2011 Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L Posts: 142
you can weld a nut to them...then safety wire to the nut. gives a nice hole for a loop.
December 27th, 2011, 07:49 AM | #6 |
L8APEX
I'd like to see someone weld a nut to plastic
December 27th, 2011, 09:10 PM | #7 |
actually we weld plastic all the time. you use hot air to melt the rod when welding instead of metal rod. very similar process to regular welding...
http://en.wikipedia.org/wiki/Plastic_welding |
December 27th, 2011, 09:18 PM | #8 |
L8APEX
so you must be talking about welding a plastic nut to it? JB sounds way eaiser.
[RoadRUNNER] - MotoMojo Spark Plugs ? What They Say About Your Engine | Ninjette Newsbot | Motorcycling News | 0 | October 15th, 2014 03:01 AM |
spark plugs | juanpak87 | 1986 - 2007 Ninja 250R Tech Talk | 12 | October 3rd, 2013 09:44 AM |
Aftermarket slipon with aftermarket header | Jojah17 | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 20th, 2011 07:58 PM |
spark plugs | postie1686 | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 7th, 2011 04:52 AM |
My plugs | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 24th, 2010 02:07 AM |
