May 21st, 2014, 05:13 PM | #1 |
Join Date: Apr 2009 Motorcycle(s): '01 Ninja 250 Posts: 62
Sealing Crankcases?
I'm in the process of rebuilding my old ninja 250
http://www.svrider.com/forum/showthread.php?t=261713 The manual calls for "Sealant: Liquid Gasket TB1216B: 92104-1064" which is ridiculously expensive. Originally I planned to use Permatex ultra black, but some research shows that's not a great idea. I see people swearing by ThreeBond 1194 and ThreeBond 1121. Has anyone here had experience with either of these products? OR any other recommendations for sealing them up? |
May 21st, 2014, 05:23 PM | #2 |
MOTM - Sep '18, Feb '16
I use the gray stuff called Honda bond. But before I put it on I clean the case half a with break clean. And I use a scotch bright to rub them down. As I put the Honda bond on I rub it around some to make sure there are no oily spots. And only leave a thin film of sealant. You don't want any squeezing inside the case. Let it set up for a little while to form a skin. Then put the two halves together.
May 21st, 2014, 05:25 PM | #3 |
which one is the thin one? kawibond or hondabond? hondabond was nice and thick and goopy right?
May 21st, 2014, 05:25 PM | #4 | |
Just to make sure I'm on the right page here. This stuff? |
May 21st, 2014, 05:56 PM | #5 |
You got it. Clean clean clean. And yes to the three bond is the stuff. Just don't use to much.
May 21st, 2014, 11:31 PM | #6 |
Ninjette Jockey
Join Date: Oct 2010 Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP Posts: A lot.
Yamabond is also excellent.
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?. |
May 22nd, 2014, 02:53 AM | #7 |
Threadkiller
Join Date: Apr 2014 Motorcycle(s): Yellow '04 stocker, '89 FJ1200, '87 Ducati Paso, '71 Yamaha XS1b, '99 KLR650, '81 FXE 80, '97 KTM 200EXC , etc Posts: 430
May 22nd, 2014, 02:58 AM | #8 |
Threadkiller
Yes.
Edit: I used some today, it's not all that thick and goopy. But it was hot today... Last futzed with by Desmoluci; May 22nd, 2014 at 05:46 PM. |
May 22nd, 2014, 09:52 AM | #9 |
Ninjette Jockey
Here's a tip that is especially good for the clutch-side cover. Put a more permanent gasket sealer on the side of the gasket toward the crankcase, and use an RTV on the side toward the cover. When it is time to change the clutch, the RTV will allow the cover to pop off cleanly and the gasket will not be destroyed. The gasket has basically been glued to the crankcase. To reseal, just rub and peel off the RTV and apply some fresh.
I have used this technique for 35 years, it is great for any cover you may want to remove cleanly later.
May 22nd, 2014, 11:20 AM | #10 |
Why has no-one mentioned....
...After applying the sealant, mating the surfaces, and snugging all bolts with minimal pressure -- wait 15 minutes before finally torquing the bolts to spec. This allows the gasket maker material to further set up and slightly harden before being torqued down to spec, ensuring that less of the gasket maker is squeezed out of the crack and lost.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
May 22nd, 2014, 11:21 AM | #11 | |
May 22nd, 2014, 12:14 PM | #12 | |
Where to get sealing washers for coolant drain bolts? | WhiteRice | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 11th, 2011 05:03 PM |
[kropotkin thinks...] - Bridgepoint Close To Sealing Deal For Infront, But MotoGP And | Ninjette Newsbot | Motorcycling News | 0 | August 22nd, 2011 10:50 AM |
[motorcyclistonline] - Lorenzo Focused on Sealing Championship at Sepang | Ninjette Newsbot | Motorcycling News | 0 | October 7th, 2010 06:00 PM |
[roadracingworld.com] - FIM Starts Sealing MotoGP Engines | Ninjette Newsbot | Motorcycling News | 0 | August 13th, 2009 12:51 PM |
