February 6th, 2012, 12:05 PM | #1 |
Your Lord Funny Bits
Join Date: Jan 2012 Motorcycle(s): 2011 Kawasaki Ninja 250 Posts: 95
Testing LED Strips
I've finally received my order of LED strips from [insert random EBay dude here] and I want to test them before I go crazy installing them.
Does anyone have a quick easy way to test these without pulling fairings off the bike? |
February 6th, 2012, 12:13 PM | #2 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 650R Posts: 317
Make yourself a couple of leads and hook them to your car battery....or the bike battery if you don't have a car.
February 6th, 2012, 12:19 PM | #3 |
Even if I connect it directly to the battery, will I have to worry about giant sparks flying up when I connect them?
February 6th, 2012, 02:32 PM | #4 |
Connect the negative terminal first (black one) when connecting things to the battery.
disconnect the positive terminal first (red one) when disconnecting things from the battery you want it grounded first before you power up the circuit. That way you don't get massive sparks. |
February 6th, 2012, 02:34 PM | #5 |
You can use a 9V battery to test the lights. Red wire goes to the pos, white goes to neg.
February 6th, 2012, 06:29 PM | #6 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Its 12v FYI
If you have a 12v adapter laying around cut off the tip and use it
----> My Youtube! <---- Unregistered, watch my youtube page! |
February 6th, 2012, 10:09 PM | #7 | |
February 7th, 2012, 09:38 AM | #8 |
KThanksBye
February 7th, 2012, 10:42 AM | #9 |
Thanks guys!
I will try this later this afternoon. Does anyone want to see an install thread done, or has that been documented to death? |
February 7th, 2012, 11:32 AM | #10 |
Join Date: Jan 2012 Motorcycle(s): 2009 Kawi 250 Posts: 118
I dont think there would be any complaints about having the same info given through another teacher. Maybe u will have better ways at explaining some things than others. But if u choos not to there is enough step by steps for us to figure it out. So if u have the time id say go for it with lots of pics please
February 7th, 2012, 11:56 AM | #11 |
Join Date: Jan 2011 Motorcycle(s): 2014 Ducati Panigale 899 Posts: 325
9v battery
You can use a regular 9v battery to test 12v led strips and bulbs. I always check new bulbs this way before I install them...
February 7th, 2012, 12:28 PM | #12 |
I just installed LED strips on mine too. Looks so cool.
----------------------------------------- --Power is nothing without control-- ----------------------------------------- |
February 7th, 2012, 01:06 PM | #13 |
OOohhhh I like those white strips. Take apart your headlight and line the bottom of it with those like Audi's then put your headlight on a relay so you can turn it off and cruise around with those Audi lights on. Baddest 250 around
February 7th, 2012, 01:19 PM | #14 |
Good idea and I thought about it BUT, I'm lazy. I'll get to it when I get a chance.
February 7th, 2012, 01:38 PM | #15 |
Join Date: Dec 2011 Motorcycle(s): 2013 636 - ABS Posts: 173
Radio Shack sells this little device for $2.59. Which is perfect for setting up small tests like this.
8x1.5v = 12v. http://www.radioshack.com/product/in...ductId=2062251 You'll probably need some of these connectors too. http://www.radioshack.com/product/in...ductId=2062219 So for about $6 you can have a nice little testing rig. Or you know just hookup a 9v battery to it. lol. You could also use this setup if you didnt want to fuss with wiring the led's to your bikes battery. Im not sure how long it would take those led strips to drain the AA batteries though. It all depends on their mAh rate. I actually have one of these things lying around, but I dont have any led strips. If I did I would wire up something and time it. There is a way to use the magical powers of math to calculate the run time, but you'd have to know all the specs of the batteries and led strips. |
February 7th, 2012, 01:59 PM | #16 |
Looks like they work! Will test the rest and get an install thread going once I get around to it. Might be a week or two. Also... on a 12V power source, they'll be brighter!?!?! #FTW
February 7th, 2012, 02:08 PM | #17 |
Also Darrell, I don't know what your wiring plans are for these babies, but it would be good to get a small project box from radio shack (one that you can hide somewhere under your fairings) and put the LED's on a fuse, and a 12V regulator. That's what I would do, because these bikes put out near 14V when at higher RPM's don't want to blow out any LED's. I would also put them on a switch so I can turn them on and off at will.
February 7th, 2012, 02:18 PM | #18 |
All of that is in the plan for the install, as well as some quick disconnect wiring for when I need the fairings off again. Thank you to everyone on here (and Google) for posting great tips. The switch has already been installed. I'll get a pic when I do the rest cause there is too much snow and she's covered atm. Got one of these installed in one of the frame plugs and am loving how factory it looks.
February 7th, 2012, 05:10 PM | #19 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
yeah 9v works just for testing to make sure they work.
I need to get some more to finish my project. I need another 7. thatll be 12 in all... WANT MY **** LIT UP LIKE ****ING CHRISTMAS. Lets see it after its done. I like looking at every ones for ideas for my own
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
February 8th, 2012, 03:26 PM | #20 |
I'm hoping to get it done this weekend, and when it's too cold to ride on Monday, I'll make sure to get pics up of the install and finished product, assuming all goes well. (Will also be shimming the carbs while she's naked)
--- Your Lord Funny Bits --- |
February 10th, 2012, 01:37 PM | #22 |
yes they do. a 12V regulator is a good idea for LED's intended for 12V
February 13th, 2012, 01:25 PM | #23 |
I did not use any regulator with mine and no issues yet for weeks now. I connected mine to the rear tail runnning light wires.
February 13th, 2012, 01:36 PM | #24 |
Cool. It's still a good idea to use one when you have a part specified for one voltage, and a system that can vary in the voltage that it delivers.
February 13th, 2012, 05:39 PM | #25 |
Correct, the battery is 12v. The charging system is 14v when the car/bike is turned on. I seriously doubt that feeding the LED strip 14v will harm it, check it specifications on the datasheet. Most leds/led strips are made to run on 11-15v anyways.
February 13th, 2012, 07:27 PM | #26 |
Case where the voltage jump blew some LED's. It's possible. Unless your LED's are designed for a range of 12V-14V, a regulator is a good idea
February 13th, 2012, 07:37 PM | #27 |
Yeah, would have gotten these installed this weekend but for the weather and sickness that just won't leave.
Don't worry, install pics and (hopefully) a write-up as soon as I get it done!
February 17th, 2012, 08:25 PM | #28 |
Woved this portion to http://www.ninjette.org/forums/showthread.php?t=96530
Wiring LED strips up as brake lights.. | KCninja | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 14th, 2014 01:38 AM |
Audi style LED strips inside headlight v. Need some advice | edxmon | 2008 - 2012 Ninja 250R Farkles | 34 | September 4th, 2013 12:34 AM |
HIDs and LED Strips.. | YMCMB | 2008 - 2012 Ninja 250R Farkles | 4 | August 8th, 2012 10:21 PM |
LED headlight strips (Warning: Picture Intensive) | Live2ride | 2008 - 2012 Ninja 250R Farkles | 12 | November 9th, 2011 06:00 AM |
