May 19th, 2011, 08:14 PM | #1 |
self wrencher
Intact chain
I was given a stock chain that has about 1000 miles on it. How does one install (or remove for that matter) an intact chain onto a bike? Do I have to cut it & use a chain link?
May 19th, 2011, 08:36 PM | #2 |
May 20th, 2011, 05:45 AM | #3 |
self wrencher
Thanks K. Is there a specific master link you would recommend? Perhaps from this list? Thanks.
http://motorcycle.motorcycle-superst...in+master+link |
May 20th, 2011, 11:29 AM | #4 |
John... yeah, here's the tricky part. I was taught to always use a master link that was designed for the particular brand and model of chain. Seeing as you are using a chain that was designed for no master link, there is no model specific ML to select.
If you still want to use the chain, select a ML from the same brand and a model that is as close to what you have. Look on one of the link plates and I believe you will see what brand and model you have. IIRC, they used either a DID or RK O-ring chain on the ninjette from the factory. Check your service manual to confirm. Let me know what ML you end up finding that fits, cause I've always wanted to hack off one link on the stock chain so I could remove it for cleaning, but have not done so due to this master link issue. |
May 20th, 2011, 07:31 PM | #5 | |
Last futzed with by CZroe; May 20th, 2011 at 08:41 PM. |
May 20th, 2011, 08:21 PM | #6 |
self wrencher
Kim
I think I would get the rivet kind rather than clip on type. I heard clipons have flew off before. Not fun I imagine...so can't take it off for cleaning if rivetted. |
May 20th, 2011, 08:27 PM | #7 |
I've used O-ring clip type ML on my cbr600s before w/o problems. what ML did you decide to go with?
May 20th, 2011, 08:42 PM | #8 |
In the time since I've kept my ear to the ground and heard that it isn't realy a concern for low HP bikes like ours, especially if we aren't racing them.
May 20th, 2011, 09:27 PM | #9 |
self wrencher
I looked at the stock chain and it's EK 520 SRO so I'll prob get that brand. Although my orig still looks perfect. I only have about 6k miles anyways. With 250 which barely has any power, I imagine the chain will last forever
May 20th, 2011, 09:33 PM | #10 |
self wrencher
May 20th, 2011, 09:39 PM | #11 |
thnx
May 24th, 2011, 04:21 AM | #12 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
I had someone try to steal my chain, while parked @ yorkdale once, without cutting it... they started removing the adjusters for the chain and pulling that apart, some people are just so stupid.
May 24th, 2011, 06:47 AM | #13 |
Wartown, USA
Im about to switch mine out. Im using a intact chain....which means Ill have to pull the swingarm which will be TONS of fun. But..its a price to pay for a solid chain with no hokey links.
May 24th, 2011, 11:15 AM | #14 |
May 25th, 2011, 05:54 AM | #15 |
possibly, but they did an awful job in either case, lol.
More chain trouble: 2-month old chain, O-Ring failure at master link. :( What now? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 56 | July 7th, 2012 05:42 PM |
[superbikeplanet.com] - Qataris Take Over Silverstone; MotoGP Deal To Stay Intact | Ninjette Newsbot | Motorcycling News | 0 | February 7th, 2012 08:10 AM |
[webbikeworld.com] - Chain Pickle Motorcycle Chain Cleaner and Degreaser Review | Ninjette Newsbot | Motorcycling News | 0 | April 1st, 2011 04:22 AM |
[crash.net - WSBK] - Haga happy to leave Misano with lead intact | Ninjette Newsbot | Motorcycling News | 0 | June 21st, 2009 12:40 PM |
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review | Ninjette Newsbot | Motorcycling News | 0 | May 18th, 2009 09:50 PM |
