#1 |
Join Date: Nov 2019 Motorcycle(s): Kawasaki GPX250r Posts: 7
carb boots
I am trying to find replacement carb boots for my 04 gpx 250 but cannot find anything. I can found allot of 88-95 and 07+, Just wondering if the 95 would fit. Im assuming the newer ones would have changed to much.
#2 | |
Join Date: Jan 2019 Motorcycle(s): GPX250 1989 model and 1990 model Posts: 98
They are the same 87 to 07. Don’t know about +07? Just make sure you put them on the correct way around. They have “carb” stamped on one end if I remember correctly which must face the carb. Putting them on the wrong way around will have a small negative effect on performance.
Perpetua Culpa Alterna Vagus Last futzed with by 59096; January 26th, 2020 at 05:47 PM. Reason: Add more info |
#3 |
Depending on market, ‘86-87 was 1st-gen and used boots #16065-1141
Pre-gen models ‘88-07 should use part#16065-1156 and can be found here: https://www.bikebandit.com/oem-parts...5-1156/b781826 New-gen ‘08-12 boots are shorter and won’t work. |
#4 | |
That’s right - the first gen had 32mm carbs I think. After that they went to 30mm so I guess the boots were a different size starting 88.
Perpetua Culpa Alterna Vagus |
#5 |
What about the airbox side boots?
#6 |
Yup, same thing. All pre-gen ‘88-07 used same air-ducts.
https://www.bikebandit.com/oem-parts...3-1307/b775148 |
#7 |
I was able to find some replacement boots. Thanks for all the help guys.
#8 |
Intake to Carb Boots | Thatdudeguybro | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 5th, 2017 10:07 AM |
Gas Tank Removal; Carb Boots | aweesner | 1986 - 2007 Ninja 250R Tech Talk | 1 | September 6th, 2011 06:53 AM |
