Old May 8th, 2023, 03:10 AM   #1
mechmike2
Mr. Ninjette newbie
mechmike2's Avatar
Rocker arm for intake valve abandoned its post..
Yes, just as the title states, a rocker arm decided it didnt wanna rock anymore and i guess it just left its pedestal and laid itself down in the cylinder head. I had noticed prior to my exploration into the top end that one valve wasnt moving while cranking the engine, carbs removed looking into the intake runners. explains why it would try to start when fuel was squirted into one carb but not the other. anyone ever have this happen tho? i think i did read somewhere that the valve lash needs to be adjusted quite often in these motors, like every 4500 miles or so? ill do some more research on it and if anyone has any tips or tricks to ease the adjustment process it would be greatly appreciated. thanks
mechmike2 is offline   Reply With Quote
Old May 14th, 2023, 04:55 PM   #2
I've sure never heard of it happening. Did something break, or did the nut come loose?
Old May 19th, 2023, 03:20 PM   #3
This is what happens when adjuster locknut is over-tightened. Breaks off one of two guides that keeps it centred over valve stem. Eventually rocker works its way out. Can also cause damage if jammed into cam-chain or tensioner. Should always use torque wrench.
http://n4mwd.blogspot.com/2013/06/ov...ts-during.html
Valve rocker arm replacement swede core 1986 - 2007 Ninja 250R Tech Talk 8 April 3rd, 2013 08:23 PM
Broke a damn rocker arm during valve adjustment. SV_Hadder 1986 - 2007 Ninja 250R Tech Talk 7 April 3rd, 2013 03:00 PM
Missing Rocker arm and valve adjust screw/nut Ragnar1x 1986 - 2007 Ninja 250R Tech Talk 45 May 22nd, 2011 09:28 AM
