June 10th, 2011, 10:03 AM | #1 |
ALRE all day
Join Date: Apr 2011 Motorcycle(s): 2009 Ninja 250R SE Posts: 107
am I crazy? neutral?
OK ever hear of this? I go riding for a bit, an hour or so when I come back home I pull into the car port and I cant get the bike into neutral. I Don't think I pulling up to hard from first.Eventually It goes in to N. Ever hear of this?
Other than that it shifts fine, No crazy jerking or lugging. |
June 10th, 2011, 10:10 AM | #2 | |
Join Date: Apr 2011 Motorcycle(s): 2009 Ninja 250R (RED) Posts: 59
You may be crazy but that would be beside the point. I hit this on my bike fairly often.
I have to push my bike in and out of my back area every day and put it in neutral to do it. It seems like after I have been riding I hit the problem, I just shift to some other gears and then back to neutral and usually it finds it pretty quick. I can't say why or how but I also have not had any other problems shifting. Quote:
June 10th, 2011, 10:13 AM | #3 |
Join Date: May 2011 Motorcycle(s): 2009 blue ninja 250r Posts: 223
Seems to happen to me when I'm moving in slow o park and I try to hit neutral. I I come to a complete stop It does not happen
If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way! |
June 10th, 2011, 10:15 AM | #4 |
how many miles do you have and have you done an oil change, yet?
exactly what are you doing right before you try to put it into neutral? |
June 10th, 2011, 10:16 AM | #5 | |
ALRE all day
June 10th, 2011, 10:20 AM | #6 |
ALRE all day
Kelly, I have 170 miles, I did the oil change at 120. I am just riding normal, I usually downshift to 2nd pull into the drive way drive into the car port, stop shift down to 1st then back up to N but sometimes it wont go into to N.
June 10th, 2011, 10:26 AM | #7 |
is the bike moving when you shift down to first? I think it has to do with how the positive neutral finder works, but I could be wrong.
try this... If you can't get it into neutral after putting it in first, try rocking the bike back and forth and see it that allows you to nudge the bike into neutral. |
June 10th, 2011, 10:26 AM | #8 |
Try a short ride and come to a complete stop then go into neutral. My bike does the same and I'm at 21 miles. Thinking this is just a noon mistake on my part and true a complete stop and it worked.
June 10th, 2011, 10:31 AM | #9 | |
ALRE all day
June 10th, 2011, 10:35 AM | #10 | |
‘94 Rider
Join Date: Nov 2010 Motorcycle(s): 1994 Kawasaki Ninja EX250F Posts: 81
So try that, and see if that doesn't fix the problem. |
June 10th, 2011, 10:39 AM | #11 |
ALRE all day
oh when i stop i am usually in 3rd or 2nd. then at a stand still i ll click it down till it cant go anymore then up one half click.
June 10th, 2011, 10:44 AM | #12 |
have you tried rocking the bike back and forth yet to see if that works?
June 10th, 2011, 11:00 AM | #13 |
Love Rival
Join Date: Jun 2010 Motorcycle(s): 2008 Ninja 250r Posts: 449
This happens to me every once in awhile. I rock it like kkim described and it goes into N. No biggie.
“Comparison is the thief of joy.” -Dwight Edwards |
June 10th, 2011, 11:13 AM | #14 |
Join Date: Jul 2010 Motorcycle(s): 09 Ninja 250r Posts: 215
If you stop while in 2 or above then downshift while stopped , on occasion, it will stick. Either shift down to first while rolling (a good habit to be in any-how) or just rock the bike a bit to get it to shift.
June 10th, 2011, 12:54 PM | #15 |
ALRE all day
OK Just went around the block, came up the drive way into the carport, put in in 1st stopped, small up click and yep there it is (N) Thanks guys
Racing in Neutral | Hero Danny | General Motorcycling Discussion | 28 | August 20th, 2014 06:24 PM |
another neutral gear?! | jenndiggity | 2008 - 2012 Ninja 250R Tech Talk | 14 | May 17th, 2011 04:33 AM |
slipping from second into neutral...? | clintalmighty | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 21st, 2011 08:43 AM |
Stuck in Neutral | ninjabadger | General Motorcycling Discussion | 11 | December 5th, 2009 11:00 PM |
False neutral | SteveL | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 26th, 2009 09:14 AM |
