June 15th, 2016, 06:44 AM | #1 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Manual Radiator Switch
I'm going to be wiring a manual radiator switch for my zx-6r. Normally when this is done you wire an aftermarket switch into the "hot" radiator wire. However, I'd like to use one of the switches that I have on the left handlebar. This includes the low/high beam switch, horn, and turn signal. I think my best bet would be the high/low switch. Could I easily wire it so that the low is "off" and high is "on"? Would I just have to wire the low as a ground...?
Any help is appreciated.
June 15th, 2016, 05:32 PM | #2 |
What a manual radiator switch is?
June 15th, 2016, 05:58 PM | #3 | |
If so, the switch is inline in the wire between the fusebox and the fan. You'll need to run power from the fusebox into your switch, then from your switch to the fan. Note that the blue/white wire going into the switch is power from the fusebox, and the blue/white wire going out of the switch runs to the fan. You can tap into both wires you need right there (though running wires from the radiator to your new switch might not be the most convenient). The headlight switch works by taking power in on the blue/yellow wire, and sending it out on either the red/yellow wire to the low beam or red/black to the high beam. There is no ground involved with that part of the circuit. Hooking something to ground there would create a short. If you want to use the high beam switch for the radiator, you'd need to take your new wire with power from the fusebox (possibly connected to blue/white #1) and run it into the blue/yellow. You'd then take the red/black output from the switch and run the wire to the fan (possibly connected to blue/white #2).
June 15th, 2016, 05:58 PM | #4 |
#squid
MOTM - Jul '16
It's a switch that turns the fan on the radiator at your leisure.
June 15th, 2016, 08:41 PM | #5 |
What its purpose is?
June 15th, 2016, 10:37 PM | #6 |
#squid
MOTM - Jul '16
Be preemptive and turned the fan on before it gets to 215, where it normally turns on. On hot days at the track, if you sit in the pit to long or you get stuck behind slower traffic, they get pretty hot.
June 16th, 2016, 06:00 AM | #7 | |
I assume then that the new switch is connected in parallel with the automatic switch, so the fan still turns on with the new switch off.
Newgen Service manual, owners manual & tool kit | Hero Danny | Motorcycle-related | 0 | September 20th, 2014 07:29 PM |
Radiator Bypass fan switch issue | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Farkles | 5 | October 2nd, 2012 09:42 AM |
