September 30th, 2010, 12:19 PM | #1 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
It is amazing what you find when you do maintenance
A beautiful day today. Went out for a ride, enjoyed every second of it, then stopped by the dealer to get oil and filter. Came back and decided I was going to work on my bike. I my oil pressure lamp was not working. Pulled the front fairing and ohmed out the light, it was good. Ok, looked at possible connections between the switch and the lamp, found the connection at the radiator to be unplugged. Not sure how, but it was, reconnected, all is well.
"Things are going good" I say in my head. I had a seized screw that connects the lower fairing to the frame. It was the bracket that hooks up by the kickstand. A while back I purchased a new bracket and screw, so I had it sitting around. Since I was doing an oil change, I figured it would be nice to not have to deal with getting oil on the plastics, so I figured I'd change that out. I misplaced my extractor set, so I decided to just drill out the screw. After about 10 minutes I was done and proceeded to replace the bracket. A balancing act was done to hold the bike up with my knee, then use both hands to reattach the kickstand and bracket (have to pull the kickstand to remove the bracket). I finished it and I thought all was well. How wrong I was. As I bent down to make sure everything was aligned properly, I see a bolt hanging out of the bike. This is buried behind the kickstand, so you can't see it unless you are down there. I pushed on it and it slid back into place. I looked around, and I was thinking for a second that it was for the center stand that I removed. Then I checked, no, the center stand hooks up differently. This is not that bolt. I stop and think. OH CRAP. The nut I was missing is for my lower engine mount. See the 92015A at the bottom (secures bolt 92002B)? Yeah that is what I was currently missing. I have been riding a bike for a little while with no lower engine mount bolt secured in place. I'm sure even the dealer wouldn't have caught that one. I looked up online an OEM dealer that has all the parts diagrams online. I found the piece myself, then went and called my local dealer. I explained that it was the 10mm nut for the lower engine mount. They had them in stock. So I drove over there in the cager and immediately picked it up. $8 later I'm heading back home to put that in (purchased a spare too). I'm lucky nothing bad happened. Could have been a whole lot worse! Next is the oil. I hope that goes smoothly! Cliff notes: Started doing maintenance; found I was missing the lower engine mount nut. Called and got a replacement; I was lucky.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
September 30th, 2010, 12:22 PM | #2 |
did you notice any added vibration from that missing engine mount nut?
September 30th, 2010, 12:39 PM | #3 | |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
It's scary the crap that happens sometimes. I almost lost my right peg mid-ride once. That was fun. There's also the time when my front caliper almost fell off....but now we're just splitting hairs. |
September 30th, 2010, 12:54 PM | #4 | |
I'll have to take it for a ride before I do the oil change. I'll do that after I eat lunch. I shall let you know if it was a big difference or not.
September 30th, 2010, 01:13 PM | #5 |
Well I took it around the block real quick and yes there is a big difference in the vibes.
To be safe, after I torqued down the bolt to spec, I checked the upper engine mount bolt (just above this one) and it was loose by 10lb-ft. Now it is like a whole new motorcycle. Much smoother now. I think I'll check those bolts from now on at every valve maintenance. I may just throw some loctite at it to try to help them stay in place too.
September 30th, 2010, 01:23 PM | #6 |
Join Date: Jan 2009 Motorcycle(s): 2008 Ninja 250 1998 HD Road King Posts: A lot.
September 30th, 2010, 01:25 PM | #7 | |
September 30th, 2010, 01:45 PM | #8 |
IC2(SW)
Little kid around here with an 07 was missing that one too. On a ride he pointed out the bolt rattling around for his center stand....... I looked and noticed it was for the engine mount
Dont know if he fixed it yet..? We swapped out his shock for an 08 the other day, I forgot to look/didnt notice. |
September 30th, 2010, 01:46 PM | #9 |
Wow. The only thing I ever found was this strange piece of plastic on my garage floor one day. Couldn't figure what the heck it was. Then I did an oil change a month later and found a similar small triangular black piece of plastic in the fairing. And 2 tabs missing from my fairings - voila.
September 30th, 2010, 02:09 PM | #10 |
Join Date: Jan 2010 Motorcycle(s): 1974 CB360 2008 Black 250 Ninja Posts: 65
Did they really charge you 8.00 for 1 10mm nut?
September 30th, 2010, 02:29 PM | #11 |
September 30th, 2010, 02:44 PM | #12 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
I would have taken the bolt to a Hardware store and bought a bolt for 8 Cents instead of $8.... Okay I exaggerate.... Maybe a quarter.
LUCKY FIND! Glad you fixed it and it didn't cause any problems, risking your safety.
Addicted to anything that has an engine and rolls. |
September 30th, 2010, 03:10 PM | #13 |
Actual price: $7.77 for two. I got a spare. I looked online and I could have gotten two OEM nuts from a site for $2.97 for a two pack. I just did not want to wait for them to be shipped.
September 30th, 2010, 03:59 PM | #14 |
LOL I know what I'm gonna be checking this weekend.
September 30th, 2010, 05:31 PM | #15 |
Mark, You would probably be surprised, but most of the metric nuts, washers, etc.---especially 10mm, are readily available at your local bicycle shop. Some hardware stores have a good assortment as well. Also don't overlook a Foreign car dealer--they are all metric as well. I have found Kawasaki to be particularly expensive, and their stuff is not all that great. I have replaced all my fairing bolts, seat attachment screws, etc. with nicely finished Stainless Steel screws. I also use Loctite Blue on everything.
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550 |
September 30th, 2010, 06:23 PM | #16 |
wats the lb/ft?
September 30th, 2010, 08:57 PM | #17 |
Britney is amazing! | Apex | Off-Topic | 3 | July 10th, 2014 03:14 PM |
Did my own maintenance | Focus Mike | 2008 - 2012 Ninja 250R Tech Talk | 8 | November 18th, 2011 08:00 AM |
Maintenance oh maintenance | etiainen | General Motorcycling Discussion | 12 | August 2nd, 2011 07:26 AM |
Maintenance | checho323 | 2008 - 2012 Ninja 250R Tech Talk | 2 | November 11th, 2010 02:53 PM |
My wife is amazing | Apex | Off-Topic | 19 | July 25th, 2010 04:43 PM |
