Old May 15th, 2013, 03:41 PM   #1
Lytning
Motorcycle(s): 08 Ninja 250r
Valve service - Conflicting decisions
So let me start out by saying I questioned the service guy at the dealer about a valve check. He told me that 95% of the time there isn't a problem and nothing needs being worked on. I know that isn't 100% and I'd be taking a risk, but should I skip the valve check until around mid way of the 15,000 service? It kind of boggles my mind being given such information from a tech.
Lytning is offline   Reply With Quote
Old May 15th, 2013, 03:44 PM   #2
krolinked
Nerd
krolinked's Avatar
Motorcycle(s): Ducati Hyperstrada
First valve adjustment is at 12.5k isn't it? What mileage are you at right now?
It doesn't LOOK that steep. But you can go first...
krolinked is offline   Reply With Quote
Old May 15th, 2013, 03:54 PM   #3
Lytning
Service manual says 7,500. I'm at 7,800 at the moment.
Old May 15th, 2013, 04:01 PM   #4
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
The tech is going off generalized information for service intervals for bikes.
I know for the 2009 Honda CBR600RR it's 15,000. For most Triumph Motorcycles it's 12,000. For the Ninja's...its already been mentioned
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old May 15th, 2013, 04:07 PM   #5
Panda
not an actual panda
I'd get the valves checked, carbs synced, spark plugs checked etc. It may be ok and it may not. It's not worth it to me to skip preventative maintenance.
Ps. Cbr is 16k valve check
Old May 16th, 2013, 12:12 AM   #6
There's a chance that they are all in spec. There's a chance that some of them aren't. That's why the check is required at 7,500 miles. If you wait thousands of miles there's a chance everything will be just fine. But if it turns out that one or more is getting quite tight, or quite loose, to the point of eventually causing some level of engine damage, the first question Kawi will ask is for evidence that you have been generally following the required maintenance schedule.
Old May 16th, 2013, 12:38 AM   #7
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
DJ Cycles does em cheap
AFM #676
Supersports are for n00bs
Old May 16th, 2013, 04:55 AM   #8
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
My first job was done at 12,000 and my valves but one needed the the very next shim size to bring them back into spec and the final remaining valve needed two steps.
My second job at 20,000 only need one valve adjusted and I probably could have just left it because it was mearly on the tight side of the range.
I plan on my next inspection at 30k then 40k and so on unless I see some major change in the adjustments needed.
300 air switching valve and purge valve (CAL) removal joyspring 2013 - 2017 Ninja 300 Tech Talk 21 February 13th, 2017 01:36 PM
Dropped bike off for valve adj. v. New valve stems? edxmon 2008 - 2012 Ninja 250R Tech Talk 14 July 17th, 2012 04:55 PM
Conflicting information about exhausts dmb5450 2008 - 2012 Ninja 250R Tech Talk 15 June 20th, 2012 02:03 PM
anyone in Berkeley, CA willing to lend me service manuals and valve adj. tools? gatoatigrado 1986 - 2007 Ninja 250R Tech Talk 3 November 8th, 2010 06:01 AM
Bike Feels a bit 'slower' after valve service. diablo250 2008 - 2012 Ninja 250R Tech Talk 0 April 11th, 2010 01:31 AM
