Old July 7th, 2018, 01:36 AM   #1
Ram Jet
Ram Jet's Avatar
New Gen Valve Float
Recently I've noted a stuttering on my 07' above 13,000 R.P.M. I thought my main jets might be a-little lean. I'm pretty sure it's valve float. I have a tach that came from an older Pre-gen and is red lined at 14,000, not the 13,000 that the 07' is red lined at. Whatcha guys think - valve float?
Bill
Old July 7th, 2018, 06:09 AM   #2
Could you be hitting the rev limiter? I've found mine. It removes spark from one cylinder briefly.
Old July 7th, 2018, 06:58 AM   #3
greg737
Motorcycle(s): -
If your '07 has it's original CDI box then the engine will be limited to the late-pre-gen redline RPM.
Old July 7th, 2018, 07:50 AM   #4
Ram Jet
Ram Jet's Avatar
Thanks TJ and Greg. I didn't know the 07' Ninja had a rev limiter. Me bad. As my friend once said to me, "Bill, stay away from the wheel barrow, you know you don't know nothin' bout machines."
Bill
Fixed valve cover bolt leak & valve clearances Linkin Videos 3 June 24th, 2015 03:49 PM
Want a current gen 250r, but I'm afraid of valve adjustments 249cc 2008 - 2012 Ninja 250R Tech Talk 19 November 12th, 2012 02:04 AM
Need a 2nd pair of eyes on pre-gen valve cover bluepoof 1986 - 2007 Ninja 250R Tech Talk 2 September 4th, 2012 03:27 PM
WTB - Pre Gen Valve Adjustment Tool Jim Moore Items Wanted 3 June 20th, 2012 07:22 AM
Carb - leaky float valve questions ako 1986 - 2007 Ninja 250R Tech Talk 34 June 15th, 2011 10:04 AM
