Old March 1st, 2013, 02:40 PM   #1
The Jackal
N00basaurus
The Jackal's Avatar
Motorcycle(s): 2009 Ninja 250r SE
Question Brand Spankin New Yoshi & Jetting.
Hey friends far-and-wide in this awesome Ninja community! This is my first post on this site so go easy on me eh.
I have just been to FedEX to pick up my brand-spanking-new Yoshimura full TRC exhaust system. As you can also see my BT-016 (rear 150/60, front 110/70) and my Factory Pro Jet-Kit have also arrived. It's nice coming back home from the bush to find shiny things at your door.
I ordered the Yoshi as I got a decent deal on it with free shipping ordered from Vancouver (my excuse for not buying Area-P).
So my question put to the forum is this. I cannot find a jetting set-up with my exact modifications in the database...and I was hoping someone would help me find a set-up to get in the ballpark for optimal performance? Please!
YEAR: 2009
INTAKE MODIFICATIONS: Snorkel Removed
EXHAUST MODIFICATIONS: Yoshimura TRC Full-Exhaust System with the baffle IN.
JET KIT OR STOCK?: Jet Kit
BRAND OF JET KIT?: Factory Pro 1.0
MAIN JET: ??
NEEDLE AND CLIP POSITION: ??
MIXTURE SCREW SETTINGS: ??
ELEVATION: Sea-level in Victoria B.C. Canada. Where temperature usually range between 10-20 degrees C (or for you Yanks 50-70 degrees F) and humidity is 75-100%.
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: I will sync carbs beforehand.
Anything else you need to know?
Thanks for your time everyone!
Also KCCO to any Chivers out there.
The Jackal is offline   Reply With Quote
Old March 1st, 2013, 03:06 PM   #2
DaBlue1
Long Time Rider
DaBlue1's Avatar
If you are leaving the airbox in, start with shimming the stock needles. See how it performs fully warmed and at WOT. For your elevation and temp range you should be OK.
Old March 4th, 2013, 02:45 AM   #3
Graugaard
Graugaard's Avatar
Motorcycle(s): Ninja 250r
sorry but i need to be sure!!!
-If you got a fuel injected ninja you can't shim the needles since it dosen't have carbs and therefor needs a chip like powercommander to make the right air/fuel mix??? Am i right?
Graugaard is offline   Reply With Quote
Old March 4th, 2013, 03:58 AM   #4
ninja250r81
ninja250r81's Avatar
before you install the headers.
weld a wideband o2 sensor bung just after the merge collector.
after you have installed the exhaust, install the wideband and watch the afr as you ride.
see if the afr are not too lean.
Jetting with Yoshimura 2-1, K&N 0990, at sea level, ~70* mr2peak 1986 - 2007 Ninja 250R Tech Talk 17 June 27th, 2014 04:24 PM
jetting & shimming tsmith3605 2008 - 2012 Ninja 250R Tech Talk 3 February 21st, 2013 10:54 AM
FS: A&L Rearset Adjusters - Brand New Toly Motorcycle-related 6 May 21st, 2012 09:18 AM
Full yoshi system/jetting question. DrJones General Motorcycling Discussion 3 April 20th, 2012 08:43 PM
Jetting for K&N Pods 1994Ninja250F 1986 - 2007 Ninja 250R Tech Talk 10 January 25th, 2011 11:44 AM
