October 9th, 2012, 11:24 AM | #41 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Just put it back together, bike wouldn't start without choke one, the more choke the better; is this normal?
I synced the carbs after the bike warmed up it seemed like the bike wanted to either rev like crazy or die from too much air (or maybe fuel). I did play around with the idle adjuster briefly which may have caused this. I noticed the float bowls were leaking fuel so i now have the carbs out and am putting gasket maker around all the flat o-rings (i'm on a budget). I may or may not try to fix the diaphrams but I'm not convinced the cut is large enough yet.... |
October 9th, 2012, 12:13 PM | #42 |
The purpose of the diaphragms is to seal. This way, when there is a pressure difference between the intake (which happens when the throttle is opened) and the top of the carb, the slides move up, equalizing the pressure difference, and opening up the insides of the carbs.
hole = no pressure difference = slides stuck in the down position = poor performance. You're going to want to fix the diaphragms. |
October 9th, 2012, 04:23 PM | #43 |
Put everything back on, now bike won't start because air/fuel mixture is whack now. How do I know how to set it? the fuel overflow hose is spilling fuel now from what i'm pretty sure is a flooded engine? I messed with the idle mix so much idk where it's even set at. I try to move it back and forth but the engine just sounds the same.....
October 9th, 2012, 04:32 PM | #44 |
ok. Start from a place we know. Set the idle mix screws to 2.5 turns out. The overflow is from the carbs
October 9th, 2012, 04:37 PM | #45 |
October 9th, 2012, 04:41 PM | #46 |
For that one, you're just going to have to start it and see what happens when it's running. If you think that's the reason that it's not starting, try starting the bike with a little throttle.
October 9th, 2012, 04:42 PM | #47 |
if you follow the idle cable to the other side of the carbs you can see the screw it turns and how it effects the throttle wheel thing.
"fuel overflow hose is spilling fuel now from what i'm pretty sure is a flooded engine?" thats the carbs flooding not the engine. that means your petcock is messed up as well as the float valve in your carbs. it wont run like that.
October 9th, 2012, 04:45 PM | #48 | |
October 9th, 2012, 04:45 PM | #49 | |
October 9th, 2012, 04:47 PM | #50 | |
October 9th, 2012, 04:51 PM | #51 |
the idle nob you are talking about is different from the idle mix screw. the black nob on the left side controls the idle speed. its the same as twisting the throttle.
i think you might want to take a moment to stop and educate yourself on how carburettors work and what the various components of them are for and how they work. once you know how it works, it will be very obvious what needs to happen.
October 9th, 2012, 04:56 PM | #52 | |
Would it help if I drained the bowls right now? |
October 9th, 2012, 05:01 PM | #53 |
I think what alex is trying to say is that the idle speed adjuster controls the "zero" position for the throttle, not the mix.
It's obviously got fuel. Try starting it without choke, and add some (just a little, gradually) throttle. If you can get it to put-put put a little, add a touch of choke and see if you can force it to run. |
October 9th, 2012, 05:03 PM | #54 | |
October 9th, 2012, 05:07 PM | #55 |
look at the obvious sign. leaking gas.
it should never leak gas out of the overflow line if your float valves are working properly. the fact that they have worked tells you nothing. they are probably gummed up and so they are getting stuck open and closed
October 9th, 2012, 05:12 PM | #56 |
Cleaned the carbs last night the pieces that attach to the floats looked good as new...
October 9th, 2012, 05:14 PM | #57 |
I agree with Alex.
Justin just introduced a new problem when trying to clean the carbs. So far, these are the problems: Broken diaphragm Broken throttle cable Leaking float valve(s)
October 9th, 2012, 05:15 PM | #58 | |
Out of curiousity- anytime gas comes out of the overflow tube is there a problem? |
October 9th, 2012, 05:17 PM | #59 |
Did you remove the mixture screws during the cleaning?
A better gasket will not stop the overflow; one or both valves are not closing properly for some reason.
October 9th, 2012, 05:18 PM | #60 | |
I took a look at the valves before I re-assembled and they were both doing what they were supposed to (visually). |
October 9th, 2012, 05:41 PM | #61 |
My diaphram tear:
October 9th, 2012, 05:58 PM | #62 |
Well I'm all out of ideas today so I guess I'll try again tomorrow I'd like to roll it down a hill right now just to get it going again!
October 9th, 2012, 06:05 PM | #63 |
Just take it easy and resume work tomorrow.
October 9th, 2012, 06:07 PM | #64 |
October 9th, 2012, 06:45 PM | #65 |
Riding an unreliable bike is not fun and dangerous.
It is going to take some patience to fix all these problems. The diaphragm may be able to seal the vacuum if you can seat it carefully. The cable is a safety must. The valves must seal because the base of the good functioning is a constant level of fuel inside the bowls. Unfortunately, you need to re-clean all the little passages, including the ones for the mix screws. Here is how: http://faq.ninja250.org/wiki/Intake
October 9th, 2012, 06:50 PM | #66 |
Did I miss something when cleaning the carbs? I could not get the pilot jets out for the life of me but I did spray every passage I could. A little strange that I assembled everything and started the bike up just fine earlier today but now cannot get bike to turn over after reassembly........
October 9th, 2012, 07:35 PM | #67 |
Too much fuel going into the engine, and maybe into the crankcase contaminating the oil, due to the carbs overflowing.
The only way to correct that is resembling the floats and valves (sometimes just tapping on the body of the carbs with the handle of a big screwdriver set the valves). If the crankshaft doesn't turn at all, the chamber(s) may be full of gas and hydro-locking (not likely). I hope your petcock closes properly Let's start over tomorrow.
October 9th, 2012, 07:58 PM | #68 | |
I use my petcock often and the fuel filter I changed just today showed that it did cut off the fuel when it was supposed to. I thought draining the bowls might do the trick but I didn't bother..... |
October 11th, 2012, 12:06 AM | #70 |
Alright, I have spark plug cleaning and draining of the float bowls planned. If the bike doesn't start after this, I will take the carbs out and check things out further....
Edit: and tapping the carbs a couple times (in case the floats are just seeing if I'm paying attention)and giving it one more try beforehand.... |
October 11th, 2012, 12:50 AM | #71 |
Also didn't think of this but I need to test the battery!
October 12th, 2012, 02:59 PM | #72 |
My battery voltage reads 12.19, when I hook it up to the booster I have it reads 12.39, will this be enough to start the bike? I still can't get it to turn over.....
October 12th, 2012, 04:22 PM | #73 | |
Jigglin' your Jiglets
MOTM - Apr '13
October 12th, 2012, 05:16 PM | #74 |
The way my physic prof described batteries:
A battery delivers continuous voltage. It is the amperage that changes, based on a chemical reaction. Sooo it can be delivering 0 amps, but still read above 12V. You need to test the voltage of the battery while it's under load. So get your multimeter ready and reading, then have someone hit the starter button. That should be a ghetto way to load test it. I think... |
October 12th, 2012, 07:59 PM | #76 | |
October 12th, 2012, 08:02 PM | #77 | |
October 12th, 2012, 08:03 PM | #78 | |
October 12th, 2012, 08:13 PM | #79 |
Join Date: Apr 2012 Motorcycle(s): 2009 Ninja 250R Posts: 209
hahaha... er, I mean, bummer.
Beards make everything better. ATGATT |
October 12th, 2012, 08:19 PM | #80 |
As far as checking out the floats as someone mentioned prior- I was looking thru my repair manual and there is actually a "fuel level" spec that you can measure with a clear tube hooked up to your carbs' drain plugs. What you do is attach clear tubing to these drain plugs and mark it in zero and mm onward increments (0, 1mm, 2mm, etc..). Put some fuel in the carbs while you hold the clear tubing 180 degrees against the carb and your zero line above where the bowl attaches to the carb (this is your reference point). After the fuel has settled you slowly lower the tubing until your zero mark lines up with where your bowl's o-ring is, or where the bowls meet the carb's body. The spec listed for '88 and later is -0.5mm (-0.020 inch) to 1.5mm (0.060 inch). Hope this helps I haven't seen this listed anywhere online so I thought I'd type it. I'm going to measure mine tomorrow even though I didn't tamper with the "tangs" at all.
08 has low power and will not rev past 10k | Donnyd21 | 2008 - 2012 Ninja 250R Tech Talk | 9 | September 17th, 2014 06:11 PM |
Bike wouldn't rev past 6k, then died | 1994Ninja250F | 1986 - 2007 Ninja 250R Tech Talk | 9 | May 9th, 2014 04:17 PM |
Won't rev past 5k :( | hoodadooda | 2008 - 2012 Ninja 250R Tech Talk | 7 | December 24th, 2012 08:56 PM |
Engine Won't Rev Past 12k | fujimumu | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 19th, 2010 03:35 PM |
Driving a cage after driving a bike | brian997 | General Motorcycling Discussion | 23 | December 21st, 2008 01:01 AM |
