#41 |
Down Under
Join Date: Jun 2014 Motorcycle(s): Kawasaki ZXR250C Ninja Posts: 296
The radiator fan is not running all the time, it comes on and off on its own.
I checked the waterpump / impeller, it's not broken. https://www.youtube.com/watch?v=lxgm0ZytOxY |
#42 |
okay, I was wrong... next contestant.
#43 |
Down Under
Head gasket aside for now, I'd been eyeing up a new exhaust for a while... and it arrived today
#44 |
Down Under
Head Gasket change prep. Engine block comes off the bottom end and has its own steel gasket on these bikes. Have a spare in case the bores are cracked or something
#45 |
Down Under
Multiple issues here. One nut was finger tight, so that doesn't help at all. Smelled horrid. Oil was very burnt and black. You can see that one of the long bolts came out with the head. I'll get to that in a bit.
![]() ![]() The head gasket was not blown, but still a bit gross ![]() ![]() ![]() So, the bolt that came out with the head. ![]() It was in the wrong way!!! ![]() The long thread goes into the block/bottom end and the short thread is for the nut on top. The nut seized on the long thread, I had to clamp the bolt in a vice grip and use a breaker bar to get it off. Now, the threads on either end... ![]() ![]() ![]() |
#46 |
Down Under
Taking all the valve buckets and shims out. All of them except a few were ~0.65in, the rest ~0.6in
![]() Yucky exhaust valves ![]() ![]() ![]() Poured petrol into the valves to check for leakage... I will let the pictures speak for themselves. ![]() ![]() |
#47 |
Fighting Texas Aggie '05
your bike > our bikes ......
#48 |
Down Under
Took the head over to a friend's place who kindly showed us what is what when it comes to valves etc, lent me the tools to get all the valves out & gave good instructions for cleaning and lapping of the valve seat surfaces.
#49 |
Down Under
Today I got all the valves out. All of the valve stem seals were hard as rocks when I pulled them out. I think I got 1 or 2 out in one piece, the rest were destroyed.
I got the block out. Itty bitty wittle pistons! Very dirty at that... ![]() Thread in the bottom end does appear to be stuffed, but I haven't forced it in the right way as I did with the spark plug threads (which are usable but not perfect) Wonder if the thread can be re-cut with a thread chaser, or if it needs a helicoil ![]() This is the cylinder base gasket. God only knows how it broke there... unless I did it when pulling it off, but I don't think so as I was careful. Luckily, the spare block I bought comes with the same gasket, and a set of pistons. I'm wondering if it would be worth using the spare block & pistons I bought (after having the measured of course) as it saves a lot of cleaning! ![]() Also unsure if this is gasket material or oil sludge... the spare gasket is just steel... ![]() |
#50 |
Down Under
Making the head and bores flat...
#51 |
Down Under
Got the headlight etc out of the way, bracket need to be welded. Mirror mount broke off.
![]() Got one of bolts out of the spare engine, it fits straight, but won't go in very far by hand ![]() Got the degreaser out and cleaned the swingarm, rear wheel and other bits. Also greased the chain. ![]() Waiting game begins... Need the stem seals, helicoil for that bolt, weld up the front bracket. |
#52 |
Down Under
Yay chinese parts!
#53 |
Down Under
Still waiting for farkin valve stem seals, so fixing up various bodge jobs from previous owners and/or mechanics... Bike was missing a fuel pump, put in the one from my spare bike, and fixed up the fuel tap on my old mans' bike.
#54 |
Down Under
Old man's FZR250 stopped running and won't start. Checked the valve clearances and it's not pretty. Almost all valves are borderline out of spec and some are way out of spec... See cyl #3 intake valves.
![]() ![]() Couple of shims have the numbers worn off or have been ground down... Time to order a shim kit. This is what the shed and concrete slab looks like at the moment... full of fizzers and fizzer parts. Only the yellow one still runs without issues! ![]() ![]() ![]() Also pictured: Vintage Triumph Bonneville, spare FZR250 engine, and various ZXR250/GSX250 parts. |
#55 |
Down Under
Picked up some stuff
#56 |
Down Under
Washing the head and cylinders in CT18 and hot water... roughly 50/50 mix. A lot of crap came off.
![]() Shiny & Clean ![]() New valve stem seals going on. Very easy to get on. Getting the old ones out not so much. ![]() Valve lapping. Used the fine paste. ![]() Spent the rest of evening hours getting all but one of the valves back in... dropped one of the little tapered bearings or whatever they are. Saw it hit the ground but couldn't find it, getting dark... Finding it will be tomorrow's task. |
#57 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
#58 |
Down Under
Ended up needing 2 helicoils for the long thread. Friend is going to experiment with machining the old pistons to see if it can be done without breaking them. Old oil rings are either out of spec or very close to it.
Old thread ![]() Job done ![]() |
#59 |
Down Under
Checked the valve clearances with the head off by using the cam caps. Easy to do with the head off, as you don't need to worry about the timing of the crank. As usual, all but one of the valves were out of spec.
![]() ![]() On another note, valve shims were posted on the 4th from the USA. Then went to Dubai and left there on the 11th. Landed in Australia and departed Sydney airport on the 12th... and then took a week to be processed by AusPost and scanned into the Granville sorting facility (which happened last night, after I rang AusPost). USPS tracking has been useful. The AusPost tracking says stuff that doesn't even match up with USPS! |
#60 |
Down Under
Got the shim kit, tomorrow I'll change them on my bike and on my dad's bike.
#61 |
Down Under
Valve shims changed out. Piece of cake with the head off.
![]() Rearranging shims where possible to avoid using up the shim kit. We added the shims from the spare engine into the kit as well. ![]() |
#62 |
Down Under
New decal kit arrived
#63 |
Down Under
So the issue with gaps between the head and the bores has been solved. The EvilBay bores are the cause. The original bores fit fine with no gaps.
2nd attempt at re-assembly halted though, due to one of the helicoils failing... caused by a little bit too much torque, due to an oopsy with the torque wrench. Completely my fault. 3rd attempt (and hopefully final assembly) begins tomorrow ![]() ![]() ![]() ![]() So close!!! |
#64 |
dirty boy
MOTM - Apr '14
looks good. Will be worth it when it is all said and done
I love the smell of burning pre-mix in the morning I don't think I'm a lot dumber than you thought that I think that I thought I was once. ![]() |
#65 |
Down Under
#66 |
Down Under
Postman dropped by and had some goodies for me
#67 |
Down Under
#68 |
Sweet!!!!
#69 |
Down Under
Put the rest of the plastic pieces on today. Fuel tap is leaking a lot less with better screws. Still have a little coolant leak out of the one the hoses to sort out, but running great. Have also finished tuning the idle circuit on the carbs, uploading that video soon.
![]() ![]() ![]() ![]() ![]() The Yellow Peril is looking a bit sad at the moment. ![]() ![]() ![]() ![]() ![]() ![]() Little bit of Inox on the switch blocks & dash does wonders ![]() ![]() |
#70 |
Down Under
#71 |
Down Under
#72 |
Down Under
Carb problem has been fixed... 2 bolts and a spring to keep track off and the 2 banks of carbs split apart. No messing with sync or balance at all!
#73 |
Inline 4!!!
Finally a build/restoration thread that appears to be seeing an end in sight! You've done a lot to that bike, this thread has been very entertaining to read through.
-I don't mean to be "that guy", but please wear a helmet though when riding. Even if it is just down the street.
#74 | |
Down Under
![]() The blue whore virgin is basically done. The last things to do are to replace the tyres (or wear out the existing ones), replace the fuel tap seals and change 1 coolant hose. I will be getting my tax refund on Monday which gives me a few grand to play with for the other bike, I'll be making a separate thread for that. |
#75 |
Freedom for Germany
Yamaha FZR250R 3LN3 | Linkin | Videos | 5 | January 23rd, 2015 07:56 PM |
Is this the toughest Kawasaki restoration project? | Ninjinsky | General Motorcycling Discussion | 2 | January 6th, 2015 06:53 PM |
1983 GR650 Restoration - Where to start? | Maielstrom | The Ex-Ninjetters Lair | 4 | September 16th, 2013 08:51 AM |
Ninjette Decal Restoration of Discussion. | Verus Cidere | Forum Information | 134 | October 20th, 2010 10:51 AM |
Tune up / Restoration questions - long post | Tommy | 1986 - 2007 Ninja 250R Tech Talk | 32 | June 26th, 2009 08:57 PM |
