May 13th, 2015, 07:29 PM | #41 |
Join Date: May 2015 Motorcycle(s): Ninja 250 Gokart Posts: 25
May 13th, 2015, 07:33 PM | #42 |
I'm just throwing things around that will get me one step closer, do you see that small wire that connects the brown/yellow to the black, how it isn't there on the bottom picture but is on the second? is that another price that I need?
May 13th, 2015, 07:47 PM | #43 |
Bottom picture is the before. Top is the after. The joint connection That you are seeing with the top picture was because I repinned harness so it matches that similar to the original oem. the Chinese one as-is would work fine but I'm just anal.
May 14th, 2015, 04:05 AM | #44 |
oh ok. well I'm at a total loss now.
May 14th, 2015, 10:39 AM | #45 |
Where are you located? I can swing by to help and guide you. One resistor should do the trick.
May 14th, 2015, 01:18 PM | #46 |
I'm located by Willowbrook, NW Houston. I'd rather you not come now because the rain is absolutely terrible & I don't want to risk your own safety, but some other day could you?
May 14th, 2015, 02:08 PM | #47 |
Yeah, you're up there. I can make a trip up there sometime when I am free. I'm hoping it's not raining when I leave work with all the traffic.
May 14th, 2015, 02:14 PM | #48 |
probably during my school summer when I'm not doing anything either, What's your number? I'll text you the details.
July 26th, 2019, 04:20 PM | #49 | |
That's because coil should ALWAYS be powered by +12v. With key ON, +12v from battery comes in on red-wire terminal, flows across coil's primary winding, and appears on other terminal of coil. So you should measure exact same +12v battery power on BOTH terminals of coil. If not, you've got coil or wiring problem. Then when cranking, ECU is what grounds black or green wires to fire coil and spark-plugs. This grounding pulse is extremely short in duration and cannot be measured by multimeter. You can only see it with 'noid-light or better yet, oscilloscope. Ignition-switch and 100-ohm resistors makes zero difference if coils are wired incorrectly. |
Spark Plug Poll | smokinsingle | Ninjettes At Speed | 15 | November 29th, 2015 08:12 PM |
Ever have spark plug go bad?? | justopelt | 1986 - 2007 Ninja 250R Tech Talk | 2 | April 12th, 2014 01:23 PM |
melted spark plug | alex.s | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 5th, 2012 12:16 PM |
Spark plug reading | Racer x | 2008 - 2012 Ninja 250R Tech Talk | 14 | October 7th, 2009 07:53 PM |
Spark plug wires | diablo250 | General Motorcycling Discussion | 1 | June 11th, 2009 05:23 AM |
