Old April 19th, 2009, 05:56 PM   #81
ninjabrewer
dirty old man
ninjabrewer's Avatar
Motorcycle(s): Blue '08 Ninja 250
Originally Posted by Sound Wave View Post
ok, changed out the rear rubber grommet. here are a couple pics of the rear cowl. i am pretty satisfied with the gap in the front. i also got the custom seat creations cover for the cowl. it is shinier than the corbin seat, but the pattern is very close if not the same. i know my bike is dirty, but all those tiny dots are not dirt. those are the sparkles from the metallic paint.
I may have to try that, Gary, good to see that you got yours to fit closer.
nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894)
www.friendsofsanonofre.org
ninjabrewer is offline   Reply With Quote
Old April 19th, 2009, 06:01 PM   #82
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Does anyone have a part number on the stand offs and grommets that work? I managed to lose one of my front ones. Good news is that it fits better now. Go figure.
Old April 19th, 2009, 06:05 PM   #83
JaeL
Bike Thrasher
JaeL's Avatar
Motorcycle(s): 2008 EX250r
looks good to me sound wave
Intuitive Sliders, Aftermarket pegs, Custom Paint, Seat Cowl, Tinted Screen, Aftermarket flush mounts, Wheel Tape, Fender Chopped, Stock Shortie Exhaust and Woodcraft ClipOns
JaeL is offline   Reply With Quote
Old April 19th, 2009, 06:05 PM   #84
Sound Wave
Ramen Rider
Sound Wave's Avatar
the rear grommet is hillman part number 139377. it is a 31/32" outer diameter and a 1/2" inner diameter. found it at lowes in the nuts and bolts section in the drawers.
for me, i just used some rubber caster looking thingys in the front. i stacked 3 of them up on each side. i will try to find my packaging.
edit: thanks guys.
edit again: corey beth.. yeah it fits better because the stock ones are too high. i bet it wobbles now though, huh? so you gotta bend the bracket as much as you can and have it still catch the lock, and you gotta put as little rubber stopper as you can without it wobbling. kind of a balancing act.
Old April 20th, 2009, 06:02 AM   #85
Buffalony
Buffalony's Avatar
I'd like to add...the stock ones are supposed to eventually settle in. It should come out fine without modding them.
Old April 21st, 2009, 11:41 PM   #86
Small Ninja
Small Ninja's Avatar
Motorcycle(s): 2008 Ninja 250 Candy Plasma Blue
i know this is off subject but where would you find those net type things people strap to the passenger seat if they dont have a cowl to haul things around?
Small Ninja is offline   Reply With Quote
Old April 22nd, 2009, 06:34 AM   #87
Buffalony
Buffalony's Avatar
http://www.ascycles.com/detail.aspx?ID=39079
Dont know how to use it on the 250. Sure youd figure something out.
Old April 22nd, 2009, 07:31 AM   #88
TnNinjaGirl
Ms. Personality
Ended up making my own little stand offs. Got some bumpers from Home Depot and used JB Weld to put them in their place. Seems to be doing a great job and they don't pop off like the OE ones do.
Old April 22nd, 2009, 10:08 AM   #89
Small Ninja
i guess ill have to figure it out
Old April 22nd, 2009, 05:21 PM   #90
JaeL
Bike Thrasher
JaeL's Avatar
I couldn't find any at homedepot!!!!!!
Old April 22nd, 2009, 09:36 PM   #91
Sound Wave
Ramen Rider
Sound Wave's Avatar
home depot didn't have the rear grommet. i got the rear grommet at lowes.
for the front bumper, i went to a local hardware store and looked in the section where they sold casters and felt pads for table legs and stuff. the rubber pads i got are meant to be placed under table legs, chair legs, etc. i just brought the stock bumper and found one that was the same diameter. i had to stack up 3 per side.
Old April 23rd, 2009, 12:27 AM   #92
B2FiNiTY
Motorcycle(s): 2009 Kawi Ninja 250R
I just got in my new rear cowl and the front of it fits HORRIBLE. wow that gap is tremendous.
B2FiNiTY is offline   Reply With Quote
Old April 23rd, 2009, 12:31 AM   #93
you sure you have the rubber bumpers installed in their correct locations?
Old April 23rd, 2009, 12:36 AM   #94
Sound Wave
Ramen Rider
Sound Wave's Avatar
do the fix and you will be fine... but yeah, it is shocking how huge the stock gap is.
Old April 23rd, 2009, 08:13 AM   #95
Buffalony
Buffalony's Avatar
I wonder if they even know theres a problem?
It does suck it has to be bent. Oh well it not that hard of a fix.
Old April 24th, 2009, 11:35 PM   #96
B2FiNiTY
I triple checked the install paperwork and it is on correctly.
The larger fatter ones go near the front of the bike while the smaller ones are near the rear tail light.
I'll take some pics in the daytime soon.
As far as this thing goes, I think I'm going to leave it as is. It's something that I don't want to mess with further unless it really ends up bothering me.
Old April 24th, 2009, 11:38 PM   #97
Buffalony
Buffalony's Avatar
Is the bracket straight? check against a flat surface.
Does the front move from side to side at all when installed?
Guess if your fine with it, just leave it
Old April 24th, 2009, 11:52 PM   #98
Sound Wave
Ramen Rider
Sound Wave's Avatar
d, yeah installed properly as shipped, there will be the huge gap. i am pretty sure you did it right.
Old April 25th, 2009, 05:13 AM   #99
py2e
py2e's Avatar
Motorcycle(s): 2009 BLACK Kawasaki Ninja 250R
same here, at least i can use the helmet hook now.
py2e is offline   Reply With Quote
Old April 25th, 2009, 08:12 AM   #100
Buffalony
Buffalony's Avatar
Me thinks the flusher the better...Is flusher a word?
Honey...the flushers broke...
Old April 25th, 2009, 05:21 PM   #101
ninjabrewer
dirty old man
That sounds like another word for the toilet.
nb
Old April 25th, 2009, 05:33 PM   #102
voodoomaster
VooDooMaster
voodoomaster's Avatar
Motorcycle(s): 2008 Blue EX250, 2007 Yamaha Virago 250
nb
No no no...that's the crapper. The flusher is some kind of think that scares quail out from the bushes right before you gonna shoot em'. Now thats a flusher.
VooDooMaster
I love the smell of Blue Octane in the morning.....
voodoomaster is offline   Reply With Quote
Old April 25th, 2009, 05:41 PM   #103
ninjabrewer
dirty old man
Wouldn't that be the same bird dog that pointed them out, after he/she is given the command to flush?
Or do you just walk up into the middle of them?
nb
Old April 25th, 2009, 07:21 PM   #104
voodoomaster
VooDooMaster
nb
Yup...reckon so...sounds like the same.
VooDooMaster
Old April 26th, 2009, 08:02 PM   #105
TnNinjaGirl
Ms. Personality
My JB welded bumpers are working great. As for the rear grommet, not so much. The rear end keeps popping out. Any suggestions?
Old April 27th, 2009, 12:56 AM   #106
Wade
Wade's Avatar
Motorcycle(s): Black 2009 Ninja 250
where did you get it from? and do they sell black?
Wade is offline   Reply With Quote
Old April 27th, 2009, 01:29 AM   #107
Sound Wave
Ramen Rider
Sound Wave's Avatar
are you talking about the cowl itself? i got mine from e-bay. they had black.
Old April 27th, 2009, 04:01 PM   #108
voodoomaster
VooDooMaster
Take a round file and file down the indent about 1/16 inch and try again. You will see that as the plastic comes off, the post stays in better to the point that you really have to pull to get it out.....the intension by design .
VooDooMaster
Old April 27th, 2009, 04:02 PM   #109
TnNinjaGirl
Ms. Personality
Thanks Dave!! I'll get right on that... tomorrow. lol. It makes sense that it would work the way you described it.
Old April 28th, 2009, 12:45 AM   #110
Sound Wave
Ramen Rider
Sound Wave's Avatar
hmm.... good idea. gotta try this too.
Old April 28th, 2009, 12:16 PM   #111
Buffalony
Buffalony's Avatar
Good idea. I did notice the rear post was alittle off from the mold.
Old April 28th, 2009, 07:37 PM   #112
voodoomaster
VooDooMaster
All. I had to file away several times, a little bit at a time until it fit correctly. I used the supplied rubbers that came with it, and did not bend the bracket. I'm happy enough with the fitment, although it could be a little flatter. The gap between the bike and the cowl is thin enough for me. Once the cowl seated into the grommet correctly, the gap reduced naturally.
VooDooMaster
Old May 4th, 2009, 11:12 AM   #113
gizmogamez
gizmogamez's Avatar
Motorcycle(s): 2009 Ninja 250R SE Green
I bought an OEM cowl cover for my sexy green beast and it fits very well. very slight gap but nothing i'd call bad or a problem, it looks just as big as my friends gsxr cover does. I do with the cover was a little tougher to remove, its not going to fall off or anything, but if someone really wanted to steal it they could stuck a key or a knife blade in the gap and with a little leverage it does pop off from the back....thinking of it now though I never did try and see if it would come out of the front locking part...so maybe i'm wrong....lol.
i know I told Nemy i'd take some pics of the bike with the cowl on for him to see, i'll try and rememebr to take pics of the gap so you can compair....maybe it's just the cheep ebay knock offs?
my OEM was only $100 +tax
Only thing that my friend commented on is that i do have to use a fair amount of force when pushing the cowl back down so that it clicks and locks.
gizmogamez is offline   Reply With Quote
Old May 8th, 2009, 01:16 PM   #114
Cochese
The Grand Royal
Cochese's Avatar
I had a PITA time with mine too when I installed it. Turns out the guy I bought it from but the rear grommets where the fronts were supposed to go. Easy fix for me. Mine never comes off. I never use the rear seat.
I bought my cowl new and uninstalled from a guy on eBay who sold his bike. I think I paid $55 IIRC.
Cochese is offline   Reply With Quote
Old May 9th, 2009, 09:34 PM   #115
B2FiNiTY
I need another rear o ring that fits better. The original one got lost somewhere and my replacement also got lost. Ugh. Any recomendations?
Posted via Mobile Device
Old May 10th, 2009, 01:20 AM   #116
Sound Wave
Ramen Rider
Sound Wave's Avatar
btw that was posted in this thread.
that has been working great for me. ninjablk08 originally posted about it. http://www.ninjette.org/forums/showt...hlight=grommet
Old May 10th, 2009, 02:02 AM   #117
B2FiNiTY
lowes here I come.
Thanks for so much help today Gary
Old May 10th, 2009, 02:24 AM   #118
Sound Wave
Ramen Rider
Sound Wave's Avatar
np. that is what the forum is for.
i know i received my fair share of help from this forum too.
Old May 15th, 2009, 01:12 PM   #119
B2FiNiTY
I picked up 2 more from lowes. The fit is very good.
Unfortunately, I lost another one. That makes the total count of lost rubber grommets to 3 now haha. Luckily I have the back up...
Old May 15th, 2009, 01:23 PM   #120
JaeL
Bike Thrasher
JaeL's Avatar
Just lost mines as well...
Rear Seat Key Hole Grommet HELP! aurbz 2008 - 2012 Ninja 250R Tech Talk 7 March 14th, 2015 12:07 AM
Rubber nubs for passenger seat? 249cc 2008 - 2012 Ninja 250R Tech Talk 13 February 3rd, 2013 11:06 PM
wtb: 08+ front cowl & solo seat cowl gt_turbo Items Wanted 3 November 9th, 2011 08:37 AM
Rubber bumper fell off my seat cowl, where can I get a replacement?? LoneRonin Items Wanted 5 October 13th, 2011 02:29 PM
Fender Eliminator, Corbin Seat, Rear Seat Cowl Installed k-os Pictures 9 February 10th, 2009 08:56 AM
