January 27th, 2012, 09:30 PM | #81 |
@smackenz I would be hesitant to cut into my headlight harness...
as long as you put a relay in the system that is energized by something that is run through the ignition, you'll be fine |
January 28th, 2012, 10:16 AM | #82 | |
Join Date: Jan 2012 Motorcycle(s): 2009 Kawi 250 Posts: 118
January 28th, 2012, 10:52 AM | #83 |
I would just put a relay in so that when the ignition is on, the magnet in the relay is activated, and the circuit for the LED's have power. Then you can add a switch on your own so that you have on/off control as long as the key is turned. as for what circuit to splice into, I would use the license plate light or gauge lights or something like that. When I wired my turn signals into DRL's, I used the power for my license plate light, since I removed my fender and was using the brake light to light my plate anyways
The headlight needs a lot of power, that's the only reason I would be hesitant to cut into the headlight harness. Plus headlight harnesses are expensive. |
January 28th, 2012, 01:51 PM | #84 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Brake light... Seriously.... Unless you dont trust your wiring skills its a great place to get power from
I use the brake light for my radar detector power
----> My Youtube! <---- Unregistered, watch my youtube page! |
July 1st, 2012, 06:52 PM | #85 |
MSF Coach!
Join Date: Jun 2012 Motorcycle(s): 2003 ninja 250 Posts: 886
does any one have a link to the ebay seller you got your led bars from? i cant seem to find them.
EDIT: found em, quick question im sure this has been asked a few times before, what kind of fuse would i need to use to wire these? im sure i need to go Power->fuse->switch->lights right? i just finished wiring a little switch with a alarm light that blinks and i was thinking the only extra thing i would need to do is add some sort of fuse box in the mix. so does any one know a good link to what i need? pre thanks!
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 |
July 2nd, 2012, 09:59 AM | #86 | |
KThanksBye
July 2nd, 2012, 10:30 AM | #87 | |
Join Date: Apr 2012 Motorcycle(s): 650r 2009 Vulcan 800 2005 Posts: 557
I used my headlight b/c if I pop the fuse, I can still run the highbeam to get home. YMMV On a similar note, my wife's Gen Coupe has pushbutton start and the brake switch failed leaving her with no way to start the car (ie press brake and click the start button). Well, if you hold the start button in for 10 seconds, it'll turn the starter for you anyway. But this left her without any brake lights for the duration of her trip to the dealer.
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there. |
July 2nd, 2012, 11:09 AM | #88 | |
KThanksBye
July 2nd, 2012, 12:32 PM | #89 | |
KThanksBye
July 2nd, 2012, 02:02 PM | #90 |
Absolutely workable idea. Perfect.
July 2nd, 2012, 06:26 PM | #91 |
MSF Coach!
seems like kevin is the yoda of 250s so i have a quick question, i made a vid on what ive done so far, and it shows where i wired an alarm indicator light to some unused wires behind the headlight. can u watch the first part of the vid and tell me what they went to and if they are safe to wire leds to? when i got the bike they where just sitting there unplugged. so i dont know if the old owner did something or removed something.
here is the link
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 Last futzed with by 7oxSin; July 4th, 2012 at 06:06 AM. |
July 5th, 2012, 11:09 PM | #92 | |
KThanksBye
I tried watching, I have no idea... I know nothing about pregens, but those cables kinda look like headlight leads
July 6th, 2012, 07:40 AM | #93 |
I can't watch on my phone, but were they those two wires with fork-style connectors and rubber hoods on the ends? If they're the same thing I'm thinking of, those are your auxiliary power wires. Those are always hot and there is a matching pair of leads next to the fuse box behind the right side body panel. Read through the ninja250.org wiki a little for some pictures since I cannot supply those right now either. You're going to want to look for an article titled "what are those extra wires?" or something to that effect in the electrical section.
The site is faq.ninja250.org in case you're unfamiliar with it. It's a great source of info on pre-2007 ninjettes. Posted via Mobile Device |
July 9th, 2012, 03:48 PM | #94 | |
MSF Coach!
