Old April 23rd, 2022, 11:08 AM   #1721
NPHendo42
Motorcycle(s): 2012 ninja 250r
I'm sorry if this is a little off topic or if there is another thread for this info. I'm looking for the A2L and CAL file to run the ecotrons software for the Gen 2 efi kit. 2012 ninja 250. Tried contacting them directly and I'm not too happy with their support, or lack thereof.
NPHendo42 is offline   Reply With Quote
Old May 6th, 2022, 05:22 PM   #1722
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Motorcycle(s): '11 CBR250R, '22 CFMOTO 300NK
Does this get you what you need?
forgive me please if you already saw this page.
jcgss77 is offline   Reply With Quote
Old May 7th, 2022, 12:48 PM   #1723
NPHendo42
No, but thanks for replying! I have since got the files I needed to connect the laptop to the ecu thankfully.
Old May 7th, 2022, 07:05 PM   #1724
jcgss77
jcgss77's Avatar
Did Ecotrons contact you with the info?
Old May 8th, 2022, 12:09 AM   #1725
NPHendo42
Pretty much. I got the files I needed to connect to the ecu to the laptop. It was weird. I had it running pretty good. Idle was hunting, but I was able to ride it fine. Then one day I just lost crank signal all of a sudden. Wouldnt start. Replaced the crank sensor and stator. Still wouldn't fire. Then I finally got the files. Got it to connect, and cranked it just to see if I could see signal on the laptop and it miraculously fired. Not sure why I lost signal.
Old May 8th, 2022, 09:34 PM   #1726
The Ecotrons ECU randomly loses its memory and settings. Have to reload the files to restore functionality. Search for other's reports, you're not 1st or only one with this issue.
Old May 18th, 2022, 05:12 PM   #1727
Ceeloo Yello
Motorcycle(s): 250
Can anyone tell me if there is an easy way to tell which connector is for injector 1 & injector 2 as they are no longer marked and have the same color coded wires?
Old May 18th, 2022, 10:56 PM   #1728
Shouldn't matter as they're not sequentially fired anyway. Unless you added cam-sensor?
Old May 19th, 2022, 10:52 AM   #1729
Ceeloo Yello
Motorcycle(s): 250
According to this thread it tunes each cylinder individually so I think it does matter.
I guess worse come to worse I have a 50/50 chance.
Old May 19th, 2022, 12:51 PM   #1730
Ceeloo Yello
Motorcycle(s): 250
Found the answer in a newer version of the manual than I had:
Pin 15 = Inj2 and Pin 16 = Inj1.
Old May 23rd, 2022, 11:51 AM   #1731
Ceeloo Yello
Motorcycle(s): 250
Do they even make 3/16" Fuel injection hose for the return line?
Old May 29th, 2022, 05:40 PM   #1732
jcgss77
jcgss77's Avatar
I have had no issues getting any of the lines needed for any of my projects at my Advance Auto. They cut hose to length, just be sure to specify for a fuel injection job up front. Customer service is a thing of the past...
Old May 31st, 2022, 02:17 PM   #1733
Ceeloo Yello
Motorcycle(s): 250
Thanks for the reply, I'll see if there are any in Honolulu.
ecotrons tech questions. bigbadbob 1986 - 2007 Ninja 250R Tech Talk 1 April 17th, 2015 10:50 AM
Ecotrons map swarfman64 2008 - 2012 Ninja 250R Tech Talk 2 January 15th, 2015 06:09 AM
WTB:Ecotrons petcock crimsondragon Items Wanted 2 September 21st, 2014 06:54 AM
Ecotrons kit garth285 Items Wanted 0 June 17th, 2014 05:09 PM
Ecotrons Gen2 FI Kit Install Terminal 1986 - 2007 Ninja 250R Tech Talk 85 October 15th, 2012 02:02 PM
