May 20th, 2012, 02:27 AM | #1 |
Join Date: Jun 2011 Motorcycle(s): Ninja 250R 2011 Posts: 16
headlight problem
My headlight went out so i went to a repair shop to get it fixed. The mechanic said the fuse was blown and put in a new fuse. After one ride it went out again. Did the fuse go out again? How can i check it. They gave me extra fuses so maybe i can replace it.
May 20th, 2012, 02:52 AM | #2 |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
You're going to be opening up the fuse box and following the diagram provided. If it keeps blowing fuses, throwing more fuses at it isn't going to fix the problem.
Life's better on the Mountain. |
May 20th, 2012, 05:48 AM | #3 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
On wire is probably getting pinched somewhere around the forks and is getting grounded.I had it happen once, and it would blow fuses when making left turns.
Posted via Mobile Device |
Mother Effin headlight problem | walty87 | 2008 - 2012 Ninja 250R Tech Talk | 141 | January 29th, 2018 09:26 AM |
Fairing above headlight problem? | MCNinja18 | 2013 - 2017 Ninja 300 Tech Talk | 9 | July 27th, 2014 01:32 PM |
Headlight problem | puma22 | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 16th, 2013 10:48 AM |
Intermittent Headlight Problem | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 3 | December 25th, 2012 05:18 PM |
Headlight Problem | Chamus57 | 2008 - 2012 Ninja 250R Tech Talk | 7 | September 29th, 2009 02:53 PM |
