#1 |
Dead-thread Necromancer!
Join Date: Sep 2008 Motorcycle(s): K5 V-Strom Posts: 144
Rear brake caliper issue
I just swapped out my brake pads, a five minute job front and rear. The fronts for evenly, but the rear set wore more on the inboard side.
![]() Has anyone ever encountered this? I've seen cars with vented rotors eat all the way to the vents on one side, barely touching the other. Caliper fail? I still have the rotor from a friend's Expedition, I'll post the pic later. ![]()
Dead-thread Necromancer! ![]() 2007 Kawasaki Ninja EX250 ZG250 Quarter-Concours commuter Gone 2005 Suzuki V-Strom DL1000 Big Black Vee future hack? |
#2 |
How much wear difference was there between the rear pads?
#3 |
About a third left on the outside pad, almost none inside.
#4 |
on my 08, the caliper piston is located on the outer side of the rear caliper. is it the same on your 07?
#5 |
Twin pistons front and rear, outboard of the disc. Probably no room to have them inboard...
On Toyota and Lexus cages, I've just added fresh grease to the pins, but I can't tell on these little units... ![]()
#6 |
From reading the manual, the caliper holder shaft needs to be lubed.
If the body does not slide smoothly, one pad will wear more than the other, pad wear will increase and constant drag on the disc will raise brake and brake fluid temperature. |
#7 | |
Rear Brake Caliper Help | blap6798 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 2nd, 2012 07:25 PM |
Rear brake caliper mounting help. | fbalsam | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 1st, 2012 08:21 PM |
Why did my rear brake caliper melt? | dino74 | 2008 - 2012 Ninja 250R Tech Talk | 17 | January 9th, 2012 12:45 AM |
Rear brake touching caliper; pedal issue? | HorizonXP | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 19th, 2011 04:33 AM |
Rear brake caliper | Reswob | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 8th, 2010 08:16 PM |
