July 4th, 2012, 08:00 AM | #1 |
Join Date: Mar 2012 Motorcycle(s): 2003 Honda Shadow, 2008 ninja 250 Posts: 237
coolant leak
Ok so the other day after a short ride to McDs I noticed a coolant leak it is leaking from the little metal piece that goes down into the head.does anyone know what could cause this? I will post a pic sometime tomorrow. I have looked it up and it is just an o ring that deals it. So I took it off and the o ring looks fine.
July 4th, 2012, 07:32 PM | #2 |
O-rings lose their compressibility over time, so even though it looks fine it probably has hardened up to the point where it (obviously) no longer seals. Just install a new one and be sure to clean out any grunge/crap on the tube and down in the hole before putting the new one on. Also, a dab of Vaseline on the O-ring will help prevent any damage from pushing the tube back into the engine.
July 4th, 2012, 07:58 PM | #3 |
So if the oring is hard its prolly no good?
July 4th, 2012, 09:18 PM | #4 |
July 5th, 2012, 11:21 AM | #5 |
so i replaced the oring and after two failed attempts at going for a ride without tightening my hose clamps all is good again
Oil and coolant leak | SwagenGTI | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 16th, 2014 11:49 PM |
Coolant leak | ttassinari48 | 1986 - 2007 Ninja 250R Tech Talk | 4 | December 23rd, 2012 11:59 AM |
Coolant Leak ?? | Redsvt | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 20th, 2012 08:24 PM |
Coolant Leak? | CaliGirl | 2008 - 2012 Ninja 250R Tech Talk | 12 | July 11th, 2009 12:54 AM |
Coolant Leak | Rawr | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 11th, 2009 12:07 AM |
