July 10th, 2012, 05:36 PM | #1 |
Join Date: May 2012 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 46
clip on questions, lots of them.
Ok so I'm going to be buying some clip ons this week and i have a few questions to get cleared up. first off, Im pretty sure im gonna go with wc's that mount under the triple clamp (with the riser) so my questions are, what is the difference in mounting clip ons that mount below and above the triple clamp (obvously the mounting position) but what else, is there any down fall the either of them, which one would give a better feel? I dont take my bike to the track but drive alot of curvy roads. Which would give better confidence and a better feel for turning? I know mounting them below the triple clamp sits the bars lower then if you mounted them above, but if you got aftermarket clip ons that mounted above, they would still sit lower then stock correct? would it make any difference? anything else i should know about?
July 10th, 2012, 09:25 PM | #2 | |
Dakine...
Join Date: Jun 2011 Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon) Posts: A lot.
July 11th, 2012, 01:23 AM | #3 |
it'll definitely add some horsepower. at very least you can tell people its to help drag elbow
July 11th, 2012, 07:18 AM | #4 |
July 11th, 2012, 08:11 AM | #5 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
I can not be a true player by playing around. |
July 11th, 2012, 08:18 AM | #6 |
Understand that clip-ons will NOT alter the bike's geometry. Therefore they will NOT alter the bike's handling.
They WILL alter the ergonomics and how you perceive the experience of riding. I installed clip-ons because I like the ergos better. This, to me, is the most important reason to do so. Those that go below the triple make more of a change, so that's what I did. You may also want to get rearset adjusters. With clip-ons you'll be pitched forward more. With the stock peg position, that might be a bit uncomfortable. Moving the pegs back and up will open your body back up a bit. |
July 11th, 2012, 02:02 PM | #7 | |
July 11th, 2012, 02:18 PM | #8 |
I have the adjusters. Not as sexy as real rearsets but waaaay cheaper and they work just fine.
Make darned sure to torque those bolts and use loc-tite! |
July 13th, 2012, 08:44 AM | #9 |
Pimpin
Join Date: Nov 2008 Motorcycle(s): Bunch of em Posts: 973
They definitely will alter the bike's handling, by moving the center of gravity forward.
Lots of oil change questions. | Ninja Rob | 1986 - 2007 Ninja 250R Tech Talk | 130 | January 8th, 2015 04:27 PM |
Room for Ninja 300 clip-ons - lots of pics | adouglas | 2013 - 2017 Ninja 300 Tech Talk | 36 | August 28th, 2013 12:29 PM |
Lots of questions! | CynicalC | 1986 - 2007 Ninja 250R Tech Talk | 9 | February 11th, 2011 09:54 AM |
Valves Job - lots of questions | indr | 2008 - 2012 Ninja 250R Tech Talk | 14 | November 24th, 2010 08:08 PM |
Total newb in Nebraska, lots of questions. | jnninja250r | New Members | 13 | August 21st, 2010 04:10 PM |
