August 7th, 2012, 09:14 AM | #1 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Head Gasket Replacement
Well boys at 22,000 and change It looks like I blew my head gasket. I have a watery mixture of oil and coolant bubbling out of the seam between the cylinder block and the head, right below the #2 cylinder exhaust port. That is what I get for running 12,000+ RPM for 60 miles a day every day for the past year. I ordered the parts I need and I will dig in this weekend. Parts should be here Monday. (Bike Bandit screwed me so I cancelled my order and went with Cheap Cycle Parts. They said that it would ship in 1-2 days, but when I placed the order they said it would take 5 to get the part, then it would ship in 1-2 days and then 2 day air. That a week and a half. Cheap Cycle Parts had it in stock and will have it to me by Monday at the latest).
Does anyone know if you put a sealant on the gasket? I didn't see any details in the manual. I hope to be running by Wednesday.
Addicted to anything that has an engine and rolls. |
August 7th, 2012, 09:19 AM | #2 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
Yes
Hondabond 4 seams to have its love all over in the motorcycle community.
THE GOOD LIFE |
August 7th, 2012, 09:22 AM | #3 |
I never put any type of sealant or adhesive on head gaskets before on all my automotive rebuilds. I imagine the same goes for motorcycle engines.
August 7th, 2012, 09:28 AM | #4 |
MOTM - Sep '18, Feb '16
Clean everything and use a new gasket.
If you want a copper head gasket. I payed the set up fee to have the gasket pattern put into the computer at copper head gaskets. com. |
August 7th, 2012, 09:47 AM | #5 |
Clean all old gasket trace with acetone or something similar; no sealant.
Tightening sequence and proper torque will do.
August 7th, 2012, 10:08 AM | #6 | |
What is the advantage of copper, other than it's malleability for a good seal? Any potential problems with using a copper and not the oem? This is the first time I've heard of this.
August 7th, 2012, 10:12 AM | #7 |
I don't have a link to the page . But if you go on the web page for copper head gaskets . Com they have a big article . I got thicker than stock gaskets to lower compression.
August 7th, 2012, 09:28 PM | #8 | |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
Seems like a copper gasket is great when dealing with modified engines as used by Racer X. For typical applications a normal crush type gasket is fine. |
August 8th, 2012, 09:53 AM | #9 |
Thanks for the advice. I've used sealant on old engines, and on an old outboard. I also did my T/A dry (newer engine). So I just wanted to check that I will do the OEM replacement dry. Thank you all.
Posted via Mobile Device |
August 13th, 2012, 12:21 PM | #10 |
I noticed to 10 holes underneath the exhaust sports on the head. does anyone know what these are for?
August 13th, 2012, 01:58 PM | #11 |
On the flat machined surface? Sounds like coolant and oil passages but I haven't had mine off so I don't know what it looks like in there.
Gasket, Exhaust Pipe C (11009-1667) fell apart? Replacement options? | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 8th, 2013 10:31 AM |
head gasket? | NorthKoast | 2008 - 2012 Ninja 250R Tech Talk | 14 | March 10th, 2012 04:01 PM |
Cylinder base gasket replacement | kevlar250 | 1986 - 2007 Ninja 250R Tech Talk | 1 | October 22nd, 2011 07:19 AM |
Re-use old head gasket ? | Tony B | 1986 - 2007 Ninja 250R Tech Talk | 10 | June 1st, 2011 06:27 AM |
copper head gasket | Racer x | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 13th, 2010 05:08 PM |
