August 13th, 2012, 10:04 AM | #1 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
need help with koso gauge
I installed everything and everything works except the speedo. It says im going 90 out of my drive way. I changed the circumference setting with the sensor point setting to 2 (which i still have no idea what it does). i changed the piston setting to 4 cylinder 2 stroke. i have the plug and play kit and directly attached the speedo cable to the adapter and its plugged into the 3 pin connector.
So do i need to install the magnet on my wheel if i have the adapter for the existing speedo cable? |
August 13th, 2012, 12:37 PM | #2 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
You want the 4 Stroke, 2 Cylinder setting.
August 13th, 2012, 12:40 PM | #3 |
Jigglin' your Jiglets
MOTM - Apr '13
I want a 2 stroke 4cyl 250
August 13th, 2012, 12:40 PM | #4 |
and you should have used 6 magnets. The setting should be set to 6 and not 2. Also re-measure your circumference and check that setting as well.
August 13th, 2012, 12:41 PM | #5 |
August 13th, 2012, 12:50 PM | #6 |
MOTM - Apr '13
August 13th, 2012, 12:51 PM | #7 |
The sensor point setting tells the gauge how many times it should check for a signal during one rotation of the tire. Therefore if you have it set to 2, then there should be two magnets on your rotor and they should be 180 degrees from each other.
August 13th, 2012, 12:59 PM | #8 |
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250r Posts: 126
If you are using the plug and play wiring for the 250 and using the adapter that comes within that goes to the speedo cable then you don't have to use the magnet.
here is the settings I have the same set up and it's accurate I compared it to my GPS. Hope this helps. |
August 13th, 2012, 01:04 PM | #9 | |
Lays er down
How long have you had your Koso gauge? | CThunder-blue | 2008 - 2012 Ninja 250R Farkles | 8 | July 10th, 2012 01:40 PM |
GB Koso Gauge Brackets | gt_turbo | Motorcycle-related | 26 | June 15th, 2012 11:54 PM |
Koso gauge and clipons | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 0 | November 7th, 2010 08:00 AM |
Koso gauge | randomwalk101 | Motorcycle-related | 7 | November 5th, 2010 07:28 PM |
Koso gauge kit GB | wellcraft | Motorcycle-related | 56 | April 29th, 2010 07:31 PM |
