August 28th, 2012, 05:07 PM | #1 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
Clutch in / resistance in 1st gear normal?
I noticed my bike, '10 with 1k miles , feels like the clutch drags in first gear
When Im sitting on my bike in 1st with clutch pulled in, trying to walk it backwards out of the garage, it was slower than if it was in neutral. Bike was not on. So I rode it, rides fine. Tried it again with bike warm, motor off. Same thing. Tried with it running , same thing. Am I crazy? Now the '09 doesn't seem to this with almost 3k on her. Any ideas?
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- Last futzed with by Bob2010; August 28th, 2012 at 05:08 PM. Reason: iPhone |
August 28th, 2012, 05:24 PM | #2 |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
Your clutch isn't adjusted properly. There shouldn't be any noticeable drag in first gear.
Put it on a rear stand, start it up, put it in first gear with the clutch disengaged. The wheel should turn just slightly and you should be able to stop it with like one finger. If it turns noticeably, your clutch needs adjusting. Follow the procedure in the manual or wiki.
Life's better on the Mountain. |
August 28th, 2012, 06:08 PM | #3 |
something similar i fouhd googling
If you could direct me to info on here, I prefer it over googling At work and can only use my iPhone at the moment.
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
August 28th, 2012, 06:21 PM | #4 |
Whoops. Newb mistake. I found "our" wiki
Trackday Gear - 1st time | Bigballsofpaint | Motorcycle Gear | 18 | August 25th, 2013 05:40 AM |
Stalling in 1st Gear at stops - HELP!!!!! | kingskater | 2008 - 2012 Ninja 250R Tech Talk | 27 | September 5th, 2012 08:39 AM |
Which Material is Best for Gear? Abrasion Resistance Tests | gfloyd2002 | Motorcycle Gear | 1 | April 15th, 2011 04:47 AM |
Finding 1st gear? | Focus Mike | 2008 - 2012 Ninja 250R Tech Talk | 38 | August 7th, 2009 01:11 PM |
1st gear locking | mista350z | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 5th, 2009 08:24 AM |
