October 21st, 2012, 09:20 PM | #1 |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
HELP! Smoke from Engine!
So I got to adjusting my valve clearances, and after i buttoned it back up and test ran it, there is smoke coming from the engine. I do not have the radiator setup, but I only ran it maybe 20 seconds before smoke started. What could be causing it?
Im 99% sure i put the cam chain and sprockets aligned properly. Idk what is wrong/
It doesn't LOOK that steep. But you can go first... |
October 21st, 2012, 10:09 PM | #2 |
Did you clean the exterior of the engine or valve cover with any solvent that may have vaporized when the engine increased the temperature?
Kerosene and WD-40 can do that.
October 21st, 2012, 10:44 PM | #3 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
----> My Youtube! <---- Unregistered, watch my youtube page! |
October 21st, 2012, 10:49 PM | #4 |
Nerd
Yes, the smoke is coming from the headers so it must be burning oil. BUT my engine is making a strange metal clanging sound, I think it is the cam chain?
Maybe Valves? And i'm getting really visible exhaust from muffler. Its like white smoke?
October 22nd, 2012, 01:08 AM | #5 |
Nerd
So it turns out the Metal clanging sound was the cam chain tensioner not being set right. I messed with it and got the clacking to go away, and the white exhaust smoke might just be cause its cold out. I noticed my r6 doing it as well.
October 22nd, 2012, 02:15 PM | #6 |
I usually get white smoke when the temperature drops at night, and is cold in the morning. Mainly comes from condensation.
October 22nd, 2012, 02:30 PM | #7 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
October 22nd, 2012, 02:43 PM | #8 |
Nerd
I did not have antifreeze in the lines at the time.
October 22nd, 2012, 03:10 PM | #9 |
What was in your lines at that time? Water? Nothing?
I guess I'm just confused why you would even start the engine if the whole thing wasn't put back together again. |
October 22nd, 2012, 06:14 PM | #10 | |
Nerd
It was on the rear stand still, didn't want to fully assemble it only to find out i have to tear back into it.
October 23rd, 2012, 06:36 AM | #11 |
If the lines were dry, that is a sure way to roast your water pump. The friction between the impeller and the wall can melt the impeller.
You may not have done too much damage, but you will have to keep an eye on it. Smoke most likely came from fluids getting on exhaust. |
Smoke 'em if ya got 'em (RZ350) | subxero | The Ex-Ninjetters Lair | 63 | July 17th, 2018 09:50 AM |
Smoke from exhaust | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 6 | January 25th, 2015 03:30 PM |
How many of you smoke? | blink | Off-Topic | 52 | October 8th, 2011 01:09 PM |
[topix.net] - Hitler's personal plane was powered by this US-designed engine [Engine | Ninjette Newsbot | Motorcycling News | 0 | June 14th, 2011 03:10 PM |
[kropotkin thinks...] - Engine List From Sepang 2010 - Engine Penalties Loom | Ninjette Newsbot | Motorcycling News | 0 | October 13th, 2010 04:00 PM |
