Old November 17th, 2012, 09:09 AM   #1
enko11
Motorcycle(s): Ninja 250 White
Winter project; 250 engine
Hello everyone, I wondering if anyone is going to modify their ninja 250s this winter or has experience building them up. I have tossed up going turbo but im just sticking to a N/A high CR combo. Pulling the engine this weekend, hoping someone here can help me out with my engine build.
First is overboring, JE has a +2mm and +4mm overbore, does anyone know if the +4mm still leaves a good amount of room for maintenance later on? Also are the walls thick enough to support that.
EFI or race carb? Im thinking the Keihin CR series right now. Have not looked into upgrading the ignition if I go this route.
The crank. Anyone deal with getting it machined, how much weight can be shaved and does it affect the clutch or lubrication in general. Planned on having it knife edged into a tear drop also.
Aftermarket cams. The BEET camshaft seems to be the only option, anyone have any input on how it affected their powerband and low end / idle quality.
Anyone go with a custom cam profile also?
I am excited to have a high output 250 engine but would love some input especially with having the crankshaft machined.
And yes I know I could just buy a bike with a larger engine, just to get that out of the way.
I can see why a 500 engine swap is tempting, much cheaper route than building this engine up with its dismal aftermarket support.
Thanks for any support you can offer!
enko11 is offline   Reply With Quote
Old November 17th, 2012, 09:24 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Is the bike going to be street strip or track? How much experience with modifications do you have?
All the answers to questions you have are some place on the forum. But I would be glad to answer what I can.
I have not done cams . But I have done rods,crank work, head work, pistons ,carbs, ignition system and nitrous on my 250 ninja.
Worlds fastest 250 ninja
Old November 19th, 2012, 09:18 AM   #3
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I'm planning on doing a basic piston swap this winter, nothing as intense as you describe. I am just planning on going to a higher CR, not overbore. But even with just a higher CR there is a lot of stuff that will likely need adjusted to get it to run smoothly.
As far as overbore, i am no expert but from what i have read you will need to get the cylinder sleeved or plated.....or something like that? I feel like if going higher than 250cc is non issue for you, you are way better off getting a 300 ninja then just do some basic performance mods to it.
If you are not overly familiar with 4stroke motorcycle engine and how to work on one and or don't have a decent amount of cash to just throw away paying for other people to do the work and your only reason for doing so is cuz you want a unique streetbike. I just think it is gonna be a PITA!!
I change my mind on my plans about just dropping new piston in and tuning because i think it is gonna be a PITA and has potential to mess up my perfectly fine engine if i get something slightly incorrect. But you are talking about complete heart surgery here with nothing to go on.
Just my 2 cents. Get informed the best you can and try and make a reasonable decision. For the cash you are talking i would be on a 300 in a heartbeat.
good luck, keep us informed, maybe start a blog if you go through with it
Old November 19th, 2012, 02:43 PM   #4
Racer x
Racer x's Avatar
If you drop in a set of 12.5 to one pistons in a otherwise stock bike you will have no tuning issues. Even with an exhaust and pod filters .After a dyno session or a couple jet changes you will love it.
Old November 19th, 2012, 03:11 PM   #5
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
what about timing?
Old November 19th, 2012, 03:58 PM   #6
Racer x
Racer x's Avatar
The stock timing is 35 deg. You could get more power with a few deg of timing. But going from 11.6 to 12.5 is not that big a jump in compression.
Old November 19th, 2012, 06:45 PM   #7
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
good to know, i will definitely want to squeeze out as much power as i can in the end but it is nice to know it will be rideable with out.
Old March 29th, 2013, 01:14 PM   #8
mgentz
Board Member
I wonder if this guy ever did any of this?
Old March 29th, 2013, 01:43 PM   #9
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Thinking not.
I think most people have big dreams... and thats about all they are especially after they realize how much work and money is involved.
My hat goes off to some of you guys, how and where you find time and energy to get all this work done.
I am still planning on doing my project, i have slowly been buying bits and pieces here and there as i squirrel away cash. I have everything i need except i have not bought the higher compression pistons yet, a little over $300 on ebay and a few odd and end things, tools ect..
Then i just need to find the time to tear into it.
Hopefully i take the time to document the mods and make something useful out of it.
winter project almost complete justopelt 1986 - 2007 Ninja 250R Farkles 10 May 5th, 2014 02:00 AM
2012 Ninja 250r SE - Winter Project...Streetfighter Version. SuperAmp13 2008 - 2012 Ninja 250R Farkles 6 April 3rd, 2014 04:34 PM
2009 r6 winter project TnNinjaGirl The Ex-Ninjetters Lair 85 February 24th, 2014 12:45 PM
iPhone/iPod Dashboard - Winter project binlagin 2008 - 2012 Ninja 250R Farkles 47 September 13th, 2010 05:55 AM
My Winter Project maxedpenny 2008 - 2012 Ninja 250R Farkles 51 March 11th, 2009 05:09 PM
