#1 |
Join Date: Feb 2013 Motorcycle(s): '06 GSXR 1K, '03 YZ450F, 95 EX250 Posts: 40
Pregen Carb Options?
So what is everyone doing for carburetion on the pregens? My club doesn't really have any restrictions on the newly-formed 250 class other than stock engine block in a stock frame. The next closest club I may consider racing in is CCS (or CSS..?) and it looks like their rulebook says it has to retain the same style of fuel delivery as stock. Carbs to carbs, EFI to EFI, no swapping.
So it looks like my options are pretty open. Obviously the goal here is to squeeze out whatever top end I can, but another huge factor for me is throttle response. Are the 31mm CR carbs a good choice ? I read they have nothing down low, but I can use my shifter pretty well so I don't see that being a problem. The bike will see 0 street time too, so that helps. Has anyone ever heard of adapting a dirt bike carb to the 250? A custom intake would be needed along with some tuning and a good deal of lateral thinking, but if I could get the responsiveness anywhere near that of a 250F, I would be a happy guy. Thoughts? |
#2 |
MOTM - Sep '18, Feb '16
The CR is a good choice. But you don't get much power increase on a stock engine. It's not that that don't have anything down low. They are not a CV carb. So if you wack open the throttle and get ahead of the RPM the engine will gasp. Once you get used to it it is nothing.
The nice thing is tuning at the track. The CR carbs make it easy.
#3 | |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
Tire options? | KillerTofu | 2008 - 2012 Ninja 250R Tech Talk | 3 | November 2nd, 2012 12:56 AM |
Handlebar options | indr | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 6th, 2011 02:16 PM |
Seat Options | sm0kediver | 2008 - 2012 Ninja 250R Farkles | 44 | August 11th, 2009 02:12 PM |
