Old May 13th, 2013, 09:32 PM   #1
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Tire Pressure Database
So this morning I was late for work, jumped on and rode. At the first corner I knew I was down by 5-8 psi. Front was heavy and it dipped pretty low. It was also 3 degrees (Celsius) and the last time I set them was at around 20 degrees. I normally check them twice a week, but its been raining for the last couple days and I figured that it wouldn't make a difference. Which is the best way to end up crashing your bike, Always check your pressures.
I find the stock setting a little to "heavy" in the front and rear to "stiff", therefore I keep them at 32 front and 30 rear. So now that the pressure's are where they're supposed to be, I got to thinking: why don't we have a Tire Pressure Database? With all the members here, living in all parts of the world, with different tires and setup, it would be neat and helpful to get an idea what people are riding on. I think it should go like this:
Tires (F/R): Pirelli Diablo Rosso II (both)
Tire Size(F/R): stock/140
Pressures (F/R): 32/30 psi
Rider Weight: 210 lbs
Suspension Mods/Preload settings: none/3rd "notch" (rear)
Average temps/location: 5-20 degrees Celsius / Toronto
Riding type: Daily driver/commuter
Other Info: I find front end more stable with an extra two pounds.
This should help members get an idea of what settings to try for their setup, it should be useful to newcomers too, and keep people thinking about their tire pressures.
Old May 14th, 2013, 05:45 AM   #2
I like your idea.
Experimentation is better than blindly using the manual's recommendation.
In hot Florida, I have found the best combination in keeping 28 psi for a front Avon and 30 psi for a Kenda rear.
Tires (F/R): Avon AM63 Viper / Kenda 671
Tire Size(F/R): 100/80-16 / 130/90-16
Pressures (F/R): 28/30 psi
Rider Weight: 185 lbs
Suspension Mods/Preload settings: none/none (pre-gen)
Average temps/location: 80 - 90 degrees Celsius (27 - 32 F) / South Florida
Other Info: Excellent performance in rain
Old May 24th, 2013, 09:22 PM   #3
Asspire
Asspire's Avatar
bump....
pretty sure the race guys would like to have some input here....
Old May 24th, 2013, 10:24 PM   #4
tubarney
pirelli diablo Rosso II
Rider weight: 170lbs
Psi - 22 to 24 front,26 to 28 rear. Have gone as low as 16 front 20 rear
Average temp - 60-95F
Front suspension mods - race tech gold valves emulators, race tech springs, preload adjusters.
That is for street riding.
Old May 25th, 2013, 05:47 AM   #5
DaBlue1
DaBlue1's Avatar
Currently running
Tires (F/R): Bridgestone Battlax BT-45
Tire Size(F):120/70-17 (R): 140/70-17
Pressures (F): 31.9 psi /2.2 bar (R): 36.2 psi / 2.5 bar
Rider Weight: 220 lbs
Suspension Mods/Preload settings: none/4th "notch" (rear)
Average temps/location: 50-90 degrees Faren. / Western NC
Riding type: Twisty rider /commuter
Other Info: The 120 front increases front end handling and stability compared to a 110 tire.
Old May 25th, 2013, 05:53 AM   #6
DaBlue1
DaBlue1's Avatar
Tires (F/R):Continental Conti-Go
Tire Size(F):110/70-17 (R): 130/70-17
Pressures (F): 31.9 psi /2.2 bar (R): 36.2 psi / 2.5 bar (manufacturer recommended)
Riding type: Twisty rider / street rider
Other Info: Tires handle better with 1-2 psi less when riding mt twisties. Ride better on hwys with manufacturers settings.
Old May 25th, 2013, 06:21 AM   #7
How can you get precise readings? .........I mean, what instrument do you use or recommend?
I cannot find any gauge able to do so.
Also, each measurement introduces a little reduction of pressure, especially in the smaller front tire.
Old May 25th, 2013, 04:18 PM   #8
kremtok
Motorcycle(s): 2016 Triumph Street Triple RX
Pressures (F/R): 32/36 psi
Rider Weight: 175 lbs
Suspension Mods/Preload settings: none/2nd "notch" (rear)
Average temps/location: 75-85°F / Honolulu
Riding type: Daily driver/commuter/Occasional trips through the twisties
Other Info: Pressures were recommended by a local shop. I experimented a little with higher and lower pressures, and that's right about where I like it to be.
We do what we must because we can.
kremtok is offline   Reply With Quote
Old May 25th, 2013, 04:32 PM   #9
Model year: 1999
Tires (F/R): Pirelli Diablo Scooter tire (both)
Tire Size(F/R): 100/80-16 and 130/80-16
Pressures (F/R): 28/32 psi
Rider Weight: 135 lbs
Suspension Mods/Preload settings: front - EX500 springs, preload spacers to compensate for difference in length from OE springs
rear - newgen shock, preload on 2nd setting
Average temps/location: 50-90 F, NE Ohio
Riding type: Sunshine commuter/backroad toy/occasional track bike
Other Info: Tires come up to temp nicely on both street and track. Likely could benefit from dropping 2 psi in front tire for track days. Rear seems great!
Old May 25th, 2013, 07:45 PM   #10
tubarney
The best I was able to find was accurate to around 0.5 P.S.I. The guy you owns the shop told me that v8 supercars (Australian Nascar) uses these and they are some of the best gauges around.
http://www.longacreracing.com/catalo...st.asp?catid=8
Old May 25th, 2013, 08:11 PM   #11
Thumbs up
Thanks, Brad
Old May 26th, 2013, 12:04 AM   #12
tubarney
Thanks, Brad
Found the email. This is an Australian distributer of longacre.
Hi Brad
The full Longacre range of gauges are among the best in the world. We don't
have a tolerance but we do supply these to Supercar teams and if they miss
the mark by half a Ib there race is done. All of the Longacre gauges are
vented unlike a lot that are out there on the market, this stops pressure
build up with temp changes which is what throws gauges out
Kind Regards,
Steve Castles
GMP Racing Products Pty Ltd.
20B Clifford St
Huntingdale
VIC 3166
Australia
TEL:+61 3 9543 6222
FAX: +61 3 95436244
www.gmpracingproducts.com.au
email@gmpracingproducts.com.au
FaceBook us here
It looks like they have all the tolerances on the page now. The 0.5 P.S.I accuracy was for a reasonably price gauge. If you want to spend 300 you can get something accurate to 0.1 P.S.I.. They have every type of gauge you can think of.
Old May 26th, 2013, 08:59 AM   #13
DaBlue1
DaBlue1's Avatar
When I use the digital gauges, I slightly overfill the tire (by a PSI or 2), then use the gauge to let out the extra air a tiny bit at a time by not seating if fully on the valve stem. Let a little out, seat fully, let a little out seat fully, until I get the desired pressure I want
This is the one I like to use the most
Slime Digital Pressure Gauge Model 20074.
I bought one 3 years ago and liked it. It worked flawlessly. I keep it in the tank bag. After a little over 3 years the unit started to display a digital code. Found out the battery could not be replaced. Contacted Slime and told them about it and they sent a free replacement. I haven't seen one in the for a while.
0-160 max PSI
It reads in Bar,Kg/cm2, KPa, and PSI. You can toggle thru them all. Has a feature to clear the last reading. I have 2 digital, one stick/pencil type and one analog tire pressure gauge and they are all .50-1 psi within each other. (IMHO not a big deal unless you are racing)
Here's a good article on tire pressure gauges and accuracy. http://www.mcnews.com/mcn/technical/200511gauges.pdf
Old May 26th, 2013, 01:16 PM   #14
Thank you very much, Blue !!!
Old July 27th, 2013, 07:48 AM   #15
Interesting related article:
"G.H. Meiser & Co. warranties its gauges for life, requesting just $3 for return shipping."
http://www.motorcyclistonline.com/ge...ge_tire_gauge/
Old July 27th, 2013, 08:59 AM   #16
quarterliter
Motorcycle(s): 2004 Ninja 250
Model: 2004
Tire: Pirelli MT75 F/R
Pressure:32 Front 34.5 Rear
Suspension mods:new gen shock 2 clicks preload (need to try 3)
Riding conditions:spirited back road riding/occasional commuter.
Rider: 130lbs without gear
Comments: so far I have had nothing to question about these tires they have never once surprised me very predictable. After I bumped up the tire 1.5 psi f/r the bike steered quicker and changed direction better.
Best tire pressure ... Davis937 1986 - 2007 Ninja 250R Tech Talk 17 February 17th, 2014 02:25 PM
Bt-45 tire pressure indr 2008 - 2012 Ninja 250R Tech Talk 1 July 5th, 2011 09:05 AM
BT-016 Tire Pressure? spencerkro 2008 - 2012 Ninja 250R Tech Talk 1 March 22nd, 2011 04:53 AM
Tire pressure.... Davidb1986 2008 - 2012 Ninja 250R Tech Talk 31 May 24th, 2010 12:59 AM
tire pressure visual ninjablk08 General Motorcycling Discussion 8 December 8th, 2009 10:01 PM
