#1 |
Join Date: Aug 2012 Motorcycle(s): '13 Ninja 300, '99 SV650 tracked Posts: 378
Gauge Mount -- Aftermarket?
So I've gutted my 300 while my plastics are off getting painted, and I removed the black plastic shroud around the the gauge; I'd like to just eliminate it completely and mount my guage somehow inside the fairing stays up front; has anyone fabbed this yet, or is there an aftermarket mount available?
there are 3 screws on the back of the OEM gauge cluster, so the bolt pattern is a bit specific but wouldn't be hard to fab; obviously the gauges are different than the analog ones on the 250, so I'm thinking I'm going to have to start from scratch. I had fabbed a gauge bracket for the Vapor gauge on my 650, but can't find it now, wonder if something similar would work with the tre-hundy. Any suggestions? Below is a pic with cowling off. .. I just used electrical tape to attach gauge to the fairing stay. Last futzed with by JBinSD; July 17th, 2013 at 12:56 PM. Reason: corrected for only "3" screws on back of gauge |
#2 |
Join Date: Jul 2013 Motorcycle(s): 2018 Ninja 400 Race Bike (in progress...) Posts: 126
I just cut the plastic shroud into 2 pieces, and then zip-tied the part that holds the gauge back deeper in the fairing bracket. I left the top part of the shroud in place so it still covers up the area you see through the windscreen. The gauge is rock solid with the 6 zip-ties holding it in place.
#3 |
thanks, looks good. can you show me the back side where you your mounted the gauge and attached it to the front cage?
#4 |
Sure, I'll snap a pic tomorrow. Basically, it's just zip-tied right inside the "square" area in the middle of the fairing bracket. It recessed down in there a couple inches farther than the stock mounting location, but it's still easily viewable from the cockpit.
#5 |
Cool, thanks. Right now my brake line hits the gauge and the clipons hit the sides of the cowls. Was going to get rid of cowl entirely but there is the gap on the front of fairings to deal with. Did you cut it with a dremel? Are you running stock or track plastics?
Thanks for the info, Joel |
#6 |
Track plastics from Catalyst Racing. I used a hacksaw blade to cut the plastic shroud.
#7 |
Cool, my bike was the prototype for Catalyst. Mike is a great guy, he didn't tell me he sold another set. Would love to see some more pics of this conversion as I'm pretty sold on doing it, and getting more room in the front fairing to lower the clipons and store transponder, timer etc. I presume your 300 is a dedicated track bike? Where are you riding/racing?
Cheers, Joel |
#8 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
You could fab a pretty good mount with sheet aluminum. It's cheap and would be an interesting design problem.
#9 |
Here's some close-up shots of the gauge mount using the hacked-off stock gauge shroud. I drilled 6 holes in it and zip-tied it to the fairing bracket on each side. Some day I'll get the dremel and file out and clean up the rough edges, and make some kind of piece to fill the gap between the top of the gauge and the top of the shroud that sits under the windscreen. Right now function trumps form!
#10 | |
#11 |
Yeah, I hear ya, I'm 45, my true race days are long gone, but the lil' bikes are easier to get up off the tarmac after a getoff. I'm sure you know already, but the guage is held to the black cowling only by those three rear bolts, I was thinking of using just the guage, and mounting it somewhere deeper like you did, but i guess if I'm willing to sacrifice the cowling and cut it up, it makes it easier to mount by using more plastic and doing it the ziptie way you did.
My cowling is already bent/thrashed from an earlier low-side, so I guess there's nothing stopping me from cutting it up. Its kinda hard to tell from your pics, is the gauge still angled back towards the cockpit, or more straight up? I'm going to get a dremel and do some carving this weekend I think, would be great to have room for both the transponder and a timer and still be able to lower the clipons. Thanks again for taking the time to explain and post pics ;-) Joel |
#12 |
Yes, it's a little flatter than the stock mount, but still plenty visible while tucked in on the bike.
Aftermarket Gauge - Gear indicator | conors891 | New Members | 7 | February 22nd, 2015 11:44 PM |
Gauge mount? | supersport | 2013 - 2017 Ninja 300 Tech Talk | 1 | June 15th, 2014 08:44 PM |
custom gauge mount?? | melfice | 1986 - 2007 Ninja 250R Farkles | 19 | April 16th, 2013 07:11 PM |
Aftermarket Gauge Questions? | Kevin2109 | 2008 - 2012 Ninja 250R Tech Talk | 13 | June 15th, 2011 01:16 PM |
