#1 |
Not on the rug... man
Join Date: Jan 2009 Motorcycle(s): 2009 Diablo Black Ninja 250r, 2009 Triumph Daytona 675 Special Edition Posts: 86
Need a liitle bit of help
So here's the throttle tube installed Just below the housing (about 5mm) there's a raised lip. Are the grips meant to go over this? Because my heated grips just will not go over this without some serious force and I just wanted to check before I maybe do some damage
Ohlins Shock,Sato Rearset,Woodcraft Clipons,Pazzo Levers.Skidmarx-Hugger/DB Screen,RG Racing-Crash Protector/Tail Tidy,Camera,HIDs,LEDs Full Yoshi,Dynojet PC3,Urbane Intake,Bergman Spin On Oil Filter |
#2 |
I slid my stock grip back up over that ridge, but it would still work if you didn't. I think the ridge is there to prevent the throttle grip from sliding off the tube, but once on, that would be pretty hard to do. Did you use some sort of glue/adhesive when you slid the grip onto the tube?
Also, with your grip not over the ridge, how's the other side?? Is the grip sticking out past the end of the throttle tube? If so, make sure it won't hang up on anything. |
#3 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
I assume their soap and water. Do our stockies have this ridge?
#4 |
I never install grips with only soap and/or water. Too many experiences when the grips get wet that they start slipping/rotating on the bars.
I used clear spray paint on mine. You can also use hairspray or they actually sell a grip glue (imagine that ![]() Can't remember if the stock tube has the ridge or not. |
#5 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R Posts: 52
yeah, the stock tube is like that too, and your throttle grip has a notch in the rubber too.
I seem to have trouble with my grips, I used clear primer, sprayed the bar and inside of the grips, but they still wont stay put. Any ideas?
'08 Ninja 250R: Yoshi Full System, HID's, FP Jet Kit, Snorkel removed, LED Brakelight, LED Footpeg Turnsignals, Zero Gravity SR Windscreen, Fender Eliminator, Solo Seat Cowl, Woodcraft Clip-Ons |
#6 |
sounds like you had a bit of grease on the tube or grips when you applied the paint and it prevented the paint from bonding well. Take the grip back off, clean up the parts with something to remove the grease and try again. If all else fails, there's grip glue.
#7 |
Pimpin
Join Date: Nov 2008 Motorcycle(s): Bunch of em Posts: 973
Use a shot of compressed air to remove/install grips. Like f^&*^&^ing magic I tell ya!
#8 |
Awesome, thanks for the help.
My heated grips don't have the recess inside to catch on that lip and the grip has a hard inner edge. So had to file the enough of the lip off till it fitted
R6 Quick turn throttle | tubarney | 2008 - 2012 Ninja 250R Tech Talk | 59 | September 6th, 2014 12:55 PM |
Motion Pro quick turn throttle | rojoracing53 | 2008 - 2012 Ninja 250R Tech Talk | 43 | May 28th, 2013 07:18 AM |
[sportrider - latest stories] - Yoyodyne Quick-Turn Adjustable Throttle | Ninjette Newsbot | Motorcycling News | 0 | December 30th, 2010 01:11 AM |
[roadracingworld.com] - Tuesday Video: Installing A Revolver Quick-turn Throttle Kit | Ninjette Newsbot | Motorcycling News | 0 | February 23rd, 2010 02:20 PM |
[roadracingworld.com] - Monday Video: Installing A Revolver Quick-turn Throttle Kit F | Ninjette Newsbot | Motorcycling News | 0 | February 22nd, 2010 02:10 PM |
