Old July 10th, 2013, 11:13 AM   #1
Ausoi
Motorcycle(s): 2008 (Black) Kawasaki Ninja 250R
RPMS not working need help
So i replaced my gauge with the koso unit because my oem one wasn't showing RPMS, to find the KOSO one isn't reading them either...
I've also replaced the CDI unit to the sportisi one, so I'm pretty stumped. I'm hoping its a bad fuse or oem wire somewhere and not the new stuff I bought. Any ideas where I should start?
Ausoi is offline   Reply With Quote
Old July 10th, 2013, 11:59 AM   #2
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
need to replace brake lines......
j/k
have you checked the wires at connector for corrosion?
Old July 10th, 2013, 12:06 PM   #3
Ausoi
you mean at the battery? I just replaced the battery too :/
I'm looking at the connectors and I can't really figure out which is for the tach/rpm gauge... BR / BK is what the user manual says. Brown and black?!
I think I get it, its the black wire because it runs to the IC igniter which is where we get our rpm reading right?
Old July 10th, 2013, 08:40 PM   #4
Asspire
Asspire's Avatar
black wire is tach, trace the black wire from IC igniter to coil #1, then to tach.
Old July 12th, 2013, 10:15 AM   #5
Ausoi
Sweet mother of GOD. Finally found the problem, it was simply the green wire on the coil was disconnected, hence no rpm reading. GOD I LOVE ELECTRONICS
RPMs too high? Lockshi3 2008 - 2012 Ninja 250R Tech Talk 67 July 29th, 2013 08:04 PM
RPMs akcalhoun 2008 - 2012 Ninja 250R Tech Talk 5 September 18th, 2012 04:43 AM
What RPMs do you cruise at? RNrider Riding Skills 24 November 14th, 2011 03:05 PM
high rpms? EngrNewf 2008 - 2012 Ninja 250R Tech Talk 40 August 23rd, 2009 07:22 AM
rpms scottyp 2008 - 2012 Ninja 250R Tech Talk 16 June 22nd, 2009 12:54 AM
