July 11th, 2013, 08:54 AM | #1 |
issues starting bike in the morning
So I have a question. Every morning for the past 3 days when I try to start my bike the thing will not turn over unless I open my gas cap first afterwards fires right up. I figured its ventilation problem so I tried blowing some compressed air down the vent hole (right side left is for fuel) and had no success it only does it in the morning. I park my bike go to work for 8 hours get off and it fires right up. Only work thats been done recently is clutch cable installed. Once running she works just fine which makes me wonder if it really is vent issues. If so what can I do to fix the vent
July 11th, 2013, 09:38 AM | #2 |
There are a couple of things you can do.
Read these; http://www.ninjette.org/wiki/Tank_whistling http://www.ninja250forum.com/index.p...09.0;msg=27547 |
July 11th, 2013, 09:43 AM | #3 | |
July 11th, 2013, 10:52 AM | #4 | |
It may take more than blowing compressed air into a vent hole. If you read the second link, I had to completely take mine apart (see the second link), enlarge the vent holes slightly, remove the rubber diaphragm and one way valves, clean them and re-lube the tumbler assembly. check the mod being done in both links. If the cap is not venting, there is a clog somewhere. I found little white crystals on the (2) one way valves and brown gunk on the larger rubber diaphragm. After I did that, not a problem since. You can mod & clean it, replace it or continue to have issues. Your choice. |
July 11th, 2013, 11:23 AM | #5 | |
Starting Issues | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 12 | January 22nd, 2015 10:33 AM |
Issues starting up | Maielstrom | General Motorcycling Discussion | 2 | August 8th, 2012 08:35 AM |
Need Help--Issues Starting Bike | riding_the_edge | 1986 - 2007 Ninja 250R Tech Talk | 13 | December 14th, 2011 03:37 PM |
Starting issues | Gorilla25 | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 22nd, 2011 09:20 PM |
Starting Issues | mikkel | General Motorcycling Discussion | 4 | July 30th, 2009 01:40 PM |
