August 5th, 2013, 11:21 PM | #1 |
Join Date: Jan 2013 Motorcycle(s): 2008 ninja 250 Posts: 16
Anyone running a ninja 300 rear wheel?
Like the title says, anyone running a 300 wheel on their 250? If so, thoughts? Impressions?
Thanks! |
August 7th, 2013, 07:52 PM | #2 |
Nobody has put the 300 wheel on their 250? It seems like the extra .5" would be nice to have.
August 7th, 2013, 08:22 PM | #3 |
No one may have put a Ninja 300 rim (in particular) on a 250, but they have put other 4.5 inch rims on one. http://www.ninjette.org/forums/showthread.php?t=71108
August 9th, 2013, 05:51 AM | #4 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
I think you will have to wait to see, the 300 is still pretty new and it will take awhile for crashed pieces to get to ebay and forums.
August 9th, 2013, 06:36 AM | #5 |
dirty boy
MOTM - Apr '14
@rojoracing53 has I think a 300 rear tire on his 250, I don't think he put the whole rim on though?
August 9th, 2013, 06:40 AM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
Correct
August 9th, 2013, 06:44 AM | #7 |
Freedom for Germany
Here you have the bigger rims in the new design for the 300.
http://indomotor77.blogspot.com/2013...eme-lebar.html |
November 12th, 2013, 09:20 PM | #8 |
Join Date: Jul 2011 Motorcycle(s): 2010 250R FI, 2006 ZX10R Posts: 175
you can look for me when it come to wider aftermarket rim
I'm Selling wider (4.5" & 5") aftermarket Wheel for N250r/N300r/Z250/Z250r |
November 12th, 2013, 09:31 PM | #9 |
November 12th, 2013, 10:03 PM | #10 |
it's plug & play
November 12th, 2013, 10:27 PM | #11 |
OK cool!
January 10th, 2014, 04:56 PM | #12 |
without a doubt
So this thread wasn't quite clear enough for me to spend hundreds of dollars on a 300r rim. Will a stock 300r rim bolt right onto a 2010 250?
January 10th, 2014, 05:15 PM | #13 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
They are saying yes the ones on that site are plug and play for your bike.
Hey Unregistered never go faster than your brakes can be applied... |
January 10th, 2014, 05:16 PM | #14 |
Ping @Peanut_EOD; I thought he had swapped the rims out and it was reasonably straightforward.
January 10th, 2014, 06:09 PM | #16 |
i ran a 300 rear on the 250 for awhile. seemed the same as the 130w irc's. no perceptible difference to me.
January 10th, 2014, 06:26 PM | #17 |
January 10th, 2014, 06:27 PM | #18 |
January 10th, 2014, 06:35 PM | #19 | |
Join Date: Feb 2011 Motorcycle(s): Green 2013 ZX-6R Posts: 723
http://www.simplysurrealphotography....es/peanut2.png |
January 10th, 2014, 06:36 PM | #20 | |
- rims set VROSSI 3" front & 4.5" rear, Plug & Play for Ninja250 (08-12) & Ninja300 (2013) - Condition: NEW - suitable for tire 120/60@70 front & 150/60 rear. also will fit 160/60/17 with small modification on chain cover bracket (better yet, just remove those chain cover) - PRICE USD265 - S&H (via Sea Mail): USD125 - Above S&H is to USA, please enquiry for Shipping to other countries - Payment method: PAYPAL
January 12th, 2014, 06:23 PM | #21 |
January 12th, 2014, 06:28 PM | #22 | |
thanks for your quote mate. some additional, vrossi rim has 6 fasteners for front disc brake. in order to install it on ninja 300r, you'll need to get 250r disc brake as new ninja 300r has only 5 fasteners for their front disc brake
January 12th, 2014, 06:30 PM | #23 |
aftermarket 5" wheel for ninja 300r does not fit ninja 250r as it's wider. need some modification. best option for ninja 250r is vrossi wheel set
January 15th, 2014, 05:25 PM | #25 |
Vrossi wheel set weight at 10.3kg (23.2lbs)
January 15th, 2014, 05:55 PM | #26 |
Join Date: May 2012 Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally Posts: 384
Thanks wandyhee...
Does anyone knows the weight of the OEM wheel set? Thanks Last futzed with by broken neck; January 15th, 2014 at 06:04 PM. Reason: to complete my post |
June 16th, 2014, 07:24 AM | #27 |
I have a 2011 Ninja 250 and mounted a 300 rear wheel on it.
Strictly a "plug and play job." It fits fine. Last futzed with by Swann; June 17th, 2014 at 02:53 AM. |
June 17th, 2014, 03:05 AM | #28 |
250R Stock 3.5" rim - 6kg. (13.2 lbs.)
300R Stock 4.0" rim - 6.7kg. (14.74 lbs.) |
October 19th, 2014, 09:32 AM | #29 |
Join Date: Oct 2014 Motorcycle(s): 08 NINJA 250,EX500,YSR50,86 VFR750 Posts: 54
Will the rear 250 rotor fit the 300 wheel? Also what size tire are you running on the 300 rear wheel? Thanks for the help
October 19th, 2014, 04:49 PM | #30 |
Yes, the rear brake rotors are the same and can be bolted on without modifications.
I use a 140/70-17 Pirelli Rosso2 on the 4.0 inch wheel. |
October 19th, 2014, 06:01 PM | #31 |
Did you notice a difference between the 250 and 300 wheel? Has anyone run a 150 rear tire on a 300 rim.
October 21st, 2014, 07:00 AM | #32 |
Join Date: May 2014 Motorcycle(s): 09 Ninja 250 Posts: 46
I would think it would work just fine. Been thinking of trying this myself. Im running and 140/70 on a 250 rear wheel right now with no issues. So with the extra .5" a 150 should equal out to be the same.
October 21st, 2014, 07:16 AM | #33 |
I just bought a 300 wheel off EBAY for $130.00
October 21st, 2014, 07:22 AM | #34 |
October 21st, 2014, 07:37 AM | #35 |
Yes, people run 150's
Paint side up, rubber side down! |
October 21st, 2014, 08:10 AM | #36 |
what is the point of using a 150 tire on a 350lb 35hp machine? you are giving yourself less traction
October 21st, 2014, 08:13 AM | #37 |
what would be the best tire and wheel combo? i have a 3.5 inch 250 wheel and a 4.0 300 wheel. i would everyones input please
October 21st, 2014, 08:17 AM | #38 |
for what purpose? there are many "bests" depending on what you will use it for.
October 21st, 2014, 08:19 AM | #39 |
Fighting Texas Aggie '05
"best" depends on what you are trying to achieve. For me "best" is fastest on track and cheaply as possible. That would mean the stock 250R wheel is "best" as it is lighter, and can fit more than enough tire I need to maintain traction - and its free. If the "best" was fastest on track without cheaply as possible it would be one of the galespeed or marcheseni forged wheels
October 21st, 2014, 08:19 AM | #40 |
alex beat me to it lol
Front and rear wheel rims, ninja 300 | AlexCWO | Items Wanted | 0 | July 21st, 2014 10:23 AM |
