Old August 14th, 2013, 06:32 PM   #1
arnoldc6
arnoldc6's Avatar
Motorcycle(s): 09 ninja 250r
can i roll start a bike if lights are off
So i was just trying to start my bike, everything were normal but when i press on the starter button, i heard a hiss sound and all my lights (indicators/head) just went off.
Is it a lossen connection? Is it possible to roll start it? I really don't want to have to spend an hour taking the bus going back and forth.
"trust me, I am not a lawyer."
arnoldc6 is offline   Reply With Quote
Old August 14th, 2013, 06:34 PM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Put it in 2nd or even third and give it a try. It's even better to have someone push you.
Old August 14th, 2013, 06:37 PM   #3
Aodrn
It's a long boring story
Aodrn's Avatar
Motorcycle(s): 2012 Ninja 250
Sounds like a dead battery. I usually put it in third and pull the clutch. You can push the 250 like a scooter. When you get up to a brisk walking pace, dump the clutch. Just make sure the bike is on and the kill switch is right. When it starts, it will lurch badly so be ready to pull the clutch again and rev the bike.
Aodrn is offline   Reply With Quote
Old August 14th, 2013, 06:42 PM   #4
arnoldc6
arnoldc6's Avatar
Oh i have done this rolling things before. Many times.
Was just worried cause not sure if even the lights won't come on would it start.
Huh.
How often do you guys take your battery out and charge it? I just had mine charge at a dealership about 2 month ago or so when doing normal maintenance.
Old August 14th, 2013, 06:47 PM   #5
Aodrn
Aodrn's Avatar
I only charge it over winter. I had a Z1000 that had a completely dead battery. It was fuel injected, so i had to roll down a hill fairly quickly and dump the clutch in 6th to get it going. Otherwise it wouldn't have any fuel pressure. All you need on the 250 is enough juice for one spark and you are good. Assuming you don't have fuel injected spec 250 in Hawaii, it should be cake
Old August 14th, 2013, 06:53 PM   #6
arnoldc6
arnoldc6's Avatar
Thanks! How fast were you going in a 1000 sixth..?
oh and, if it were a connection thing instead of battery, is it still possible to roll start it?
Old August 14th, 2013, 06:56 PM   #7
quarterliter
Motorcycle(s): 2004 Ninja 250
The bike will run without a battery but not well........
Old August 14th, 2013, 06:57 PM   #8
quarterliter
And its called bump starting
Old August 14th, 2013, 07:06 PM   #9
arnoldc6
arnoldc6's Avatar
I manage to get it started twice, but both time the engine just sputtle and sounds like it's about to die. Then it actually does on me. If I pull it into a bigger incline (there is one right next to me lot) will the speed help it last longer? Because I don't have to tool at home and there is no way it will last till I get to the shop which is like 8miles away.
Old August 14th, 2013, 07:26 PM   #10
quarterliter
The bike did come with a took kit. Make sure the headlight is on low beam so there is less draw on the battery. All you need to reconnect the battery is a JIS screwdriver but a philips will work too. Try second gear or third. All you are trying to do is get it in a tall enough gear so it wont lock up the rear tire. So if 2nd doesnt lock up use it it will give you more RPM on startup. Full choke second gear or third pop clutch pull in clutch once running keep the revs around 3k if you can to charge the battery in neutral.
Old August 14th, 2013, 07:27 PM   #11
Aodrn
Aodrn's Avatar
You may have a bigger problem then. Are your fuses ok? If a battery shorts inside itself, it can cause similar symptoms. If there is a way to load test it, that would eliminate a big variable.
Two things that have bitten me more than once. Is the kill switch on and does the bike really have gas. I always over think and miss the obvious.
Old August 14th, 2013, 08:57 PM   #12
arnoldc6
arnoldc6's Avatar
yep. Both are a-ok for sure.
Man it maybe charging system too? this thing is less than a year old.
and light.. I doubt if the headlight is even on. If yes it's still bearly visible..
Old August 14th, 2013, 09:28 PM   #13
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
did the dash lights come on when push started?
is the bike cold when you push started it? have you tried it with the choke on?
when it did start, and died after, was the low beam on?
was the headlight on before you started it? does the brake light work? need moar info plz.
can you afford an R6?
Old August 14th, 2013, 09:44 PM   #14
arnoldc6
arnoldc6's Avatar
not sure about brake lights but my dash were all dark so I would assume it ain't.
Not cold. Was at campus just got there two hours ago to study.
huzz.. not sure how to describe it. Tach won't working but it sounds like it was idling at less than 1k. Sounds like it was suffocating.
When I was driving at sixth gear full throttle on my way out it was just doing 16mph or so. In first gear full throttle it max out at 4mph. I drove like a retard during rush hour traffic.
Old August 14th, 2013, 09:55 PM   #15
Asspire
Asspire's Avatar
Old August 14th, 2013, 10:26 PM   #16
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
So how dose one go about putting the bike in 2nd with the positive neutral finder on are bikes? I can not get it past N even when I am rolling it forward.
Old August 15th, 2013, 10:06 AM   #17
quarterliter
Yea truthfully I have the same issue I thought my bike was just weird but it makes sense now.
Old August 15th, 2013, 10:56 AM   #18
Aodrn
Aodrn's Avatar
I just got my 250 as a track bike recently. I didn't realize it wouldn't go to second. Is there a way to bypass that if need be. I suppose the motor is small enough that a first gear bump would do the job
Old August 15th, 2013, 03:38 PM   #19
arnoldc6
arnoldc6's Avatar
Ok you are just easing me. What happen? How did you deal with it?
Old August 15th, 2013, 03:39 PM   #20
arnoldc6
arnoldc6's Avatar
I just use first. Its easy just remeber to pop clutch when you are IN first gear.
It took me half an hour my first time to realise poping it in neutral doesn't do ****.
Old August 15th, 2013, 03:40 PM   #21
arnoldc6
arnoldc6's Avatar
There is a thread about this. Reckon its written by alex dont really remember.
Old August 15th, 2013, 03:41 PM   #22
arnoldc6
arnoldc6's Avatar
tell me moai. What do you think causes it?
Old August 15th, 2013, 07:19 PM   #23
arnoldc6
arnoldc6's Avatar
Ok my ninja bros. My battery is very fine. So is fuse. Drop it off at the dealership and they are gonna take it apart.
Hope it doesn't take them too long its $89 per hour
Oh and its a suzuki dealership (don't want to get a tow truck, Kawa is another 7 miles or so) so i hope they know much too.
Can't be too bad tho have seen at least 3 250's there.
Old August 24th, 2013, 07:21 AM   #24
BikersPOV
BikersPOV's Avatar
Motorcycle(s): Ninja 250R
I had been trying to start my previous bike (cbf 250) this way and failed miserably... not sure what I have been doing wrong but what I did was not enough... not sure if it will help anyone but I have it recorded
I like my Froggie!
BikersPOV on Facebook; BikersPOV on Youtube
BikersPOV is offline   Reply With Quote
Bike won't start. Dash lights up...sometimes.. kdogg2077 2008 - 2012 Ninja 250R Tech Talk 20 July 4th, 2014 12:01 PM
[topix.net] - Bike lovers roll into boot camp Ninjette Newsbot Motorcycling News 0 April 13th, 2013 02:00 AM
Electric start problem, lights, blinkers, and indicator lights work. claymaker 1986 - 2007 Ninja 250R Tech Talk 8 July 10th, 2012 07:04 PM
2007 won't start, not even getting neutral or oil warning lights! davidfriend 1986 - 2007 Ninja 250R Tech Talk 13 May 6th, 2011 09:51 PM
Bike finally ready to rock and roll krbreton General Motorcycling Discussion 3 June 18th, 2009 10:00 AM
