October 1st, 2013, 08:57 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2008 ninja 250 Posts: 271
shim kit question
Hi please forgive my questions, but Is it necessary to purchase a entire shim kit to do the valve clearance job, I see some kits are going for around 70 dollars is that about right?
I see this bike needs 7.48 od shims, but was wondering if I could just purchase certain sizes, Thanks. |
November 2nd, 2013, 09:06 PM | #2 |
Pinging @choneofakind.
November 2nd, 2013, 10:10 PM | #3 |
Not my area of expertise, but I think I can still be of some help.
If you know exactly what thickness you need, you should be able to go to a dealership with a part number and order them. You may or may not have to wait for them because they may or may not be in stock. Kinda like buying jets individually. However, I think I remember @rojoracing53 talking with another member a while back about buying a shim kit for dirt bikes instead of one specific to the ninja 250. It ended up being cheaper and worked just fine because those are a common size shim. Sorry I'm not much help, I own a pregen. My knowledge of the newgen is limited to reading and the work I've done on my buddy's '11 model. Thankfully no valve jobs on that one yet. I think Alex is just getting old and senile and is confusing me with someone else |
November 3rd, 2013, 02:39 AM | #4 |
Don't worry, he's already old and senile. I know there is someone on this site who is all for people buying individual shims rather than a shim kit; thought it may have been you.
November 3rd, 2013, 06:06 AM | #5 |
If you want to finish in one day (and don't want to pay $7-$9 each at the dealer) then get the kit. If you can deal with not riding for a few days, measure everything and order individual shims.
There are several places online. I have ordered from Jake Wilson several times. They do not list the 250 but an '02 ZX6R uses the same size.
November 3rd, 2013, 07:52 AM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
Yeah I'm using the old 7.48 hot cams shim kit I bought 8 years ago for my YZ250f dirt bike. All 7.48 kits are the same. Sure its going to cost you an extra $40-50 for the whole kit but it's totally worth it to get the job done in one day. There's a lot of **** to take apart so I'd rather not have to try and remember how to put it all back together 4 days later.
Its a 2-3hr job if you know what your doing but it took @CycleCam303 like 17hrs over two days to get his done with me supervising him for his first time. |
November 3rd, 2013, 07:18 PM | #7 |
ok thanks
Looks like a lot work I guess the first thing is to be able to get everything to a point where I can measure the valve clearance first,
November 3rd, 2013, 07:31 PM | #8 |
Fast-Guy wannabe
MOTM - Jan '13
My first inspection I had to adjust every valve, my second and third inspection I didn't have to adjust any.
November 3rd, 2013, 07:36 PM | #9 |
that has to be a great feeling
Having the clearance with in spec, no further questions
November 3rd, 2013, 08:08 PM | #10 |
Join Date: Jan 2013 Motorcycle(s): 2009 Ninja 250R Posts: 206
November 3rd, 2013, 08:37 PM | #11 |
I picked this bike up with 14,000 miles. I am going to assume from the condition of the bike it was never done. Although the bike runs perfect.
November 3rd, 2013, 09:10 PM | #12 |
Fast-Guy wannabe
MOTM - Jan '13
1st was 12K
2nd was 20K 3rd was 30K next will be 40K |
November 3rd, 2013, 09:14 PM | #13 | |
Fast-Guy wannabe
MOTM - Jan '13
November 3rd, 2013, 09:38 PM | #14 |
wow
it is very encouraging to see how many other people have higher mileage as well,
November 4th, 2013, 05:50 AM | #15 |
I checked mine at 12k as well. All four exhaust valves were out and two of the intake valves were getting close so I adjusted them as well. Hopefully I don't have to adjust mine again. Did the clearances stay exactly the same for yours after the first adjustment?
November 4th, 2013, 06:04 AM | #16 |
Fast-Guy wannabe
MOTM - Jan '13
I don't recall exactly but I think I adjusted to the open end of the range the first time and they moved to the middle for the second. The third they were practly the exact same as the second inspection.
Carb Needle Shim Question/Bike Idle | haloninja117 | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 8th, 2014 01:14 PM |
general shim under bucket question | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 30th, 2013 11:09 AM |
Fuel Mixture Question - Shim or Jet for this set-up? | folky15 | 2008 - 2012 Ninja 250R Tech Talk | 20 | April 23rd, 2012 06:21 PM |
Quick shim question | Gorilla25 | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 2nd, 2011 10:20 PM |
Quick Shim question | shadowskater | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 28th, 2011 08:41 PM |
