October 25th, 2013, 08:34 AM | #1 |
Hub spacer sleeve size differences
Someone please tell me why there are two sizes of spacers. Once is 25mm and the other is 30mm. I came about this when I was trying to swap sprockets onto my spare hub.
Spare hub was from a 2009 with a 30mm spacer whereas my 2010 came with a 25mm spacer. pn: 42036
October 25th, 2013, 10:30 AM | #2 |
Board Member
You mean the I.d.? As in the axles are different sizes? Or just oal as your pic shows?
October 25th, 2013, 10:55 AM | #3 |
Sorry I was referring to the length. Inner ID for the axle is the same between the two.
October 25th, 2013, 12:40 PM | #4 | |
Starting in 1996, all the pre and new-gen models came with that same part measuring 30 mm (same as Ninja 500), even when they kept the same Kawa part code 42036-1217. If you Google that part number, the engine will find both lengths. That may have been the reason for a 25 mm being used in a new-gen. Over those years, the only other parts of the assembly that changed were 41068 (axle), 92143 (bearings separator) and 42033 (coupling assembly).
October 25th, 2013, 05:29 PM | #5 |
Board Member
Crazy. How do you know that?
October 25th, 2013, 05:57 PM | #6 |
MOTM - Sep '18, Feb '16
First gen spacer is longer. I have a couple hubs I put gears on. Makes changing sprockets super fast. One day I could not get the wheel in. That is when I found out about the difference.
October 25th, 2013, 08:12 PM | #7 |
Good to know Eric! I'll see if I can get it swapped out for the correct one
Is My Axle Spacer on Right? | Hatter | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 19th, 2015 12:07 PM |
New Gen front bearing spacer | willi777 | Items Wanted | 0 | September 11th, 2013 05:25 PM |
WTB New Gen speedo spacer | pjed | Items Wanted | 1 | June 28th, 2012 05:56 PM |
WTB: Front Axle Wheel Spacer | Kangxi | Items Wanted | 11 | June 13th, 2012 02:24 PM |
Rear Adjustment Spacer | kerheads | 2008 - 2012 Ninja 250R Tech Talk | 1 | February 24th, 2012 09:51 AM |
