October 27th, 2013, 10:40 PM | #1 |
Join Date: Mar 2011 Motorcycle(s): 96 Ninja 250EX , 87 CBR 1000, 86 TRX 260R, 86 KXT 250, 84 ATC 200X, 82 ATC 250R (w/CR480) Posts: 134
Camshaft questions 86,87 vs 88+
Ok here goes .. I've kind of heard a little buzz about some camshaft differences.. I've heard a few different opinions.. Basically is there a difference between the 86-87 cams and the 88+ ones .. What I've heard is the 86 ones offer a slight performance upgrade over the 88+ ones... Is his true and will the early ones bolt in to the later modem heads...
November 2nd, 2013, 09:05 PM | #2 |
It looks like the folks I'd recommend to take a look at this thread already have and haven't responded.
November 2nd, 2013, 09:32 PM | #3 | |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
the cams from 88-90 had different ignition configuration so got the larger duration cams. before 88 were the ones that the 91-07 used. I have confirmed with my 1990 cams and cams I have from an 04.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
November 2nd, 2013, 10:19 PM | #4 |
^^^ I've gone and done the same research, but using the parts diagrams. There's a little inconsistency on whether the last cutoff is '92 or '91, but I'm going to believe Byron over the parts numbers. 88-90 are the ones with the hot cams.
Fun part: The hot cams shouullllld be a straight swap. If you look at the parts diagrams, every part is the same in the head for the whole run of the 88-07 bike. Everything except the cams that is. This leads me to believe that the cams will work with the same head and same cam covers and same cam chain and same valves/rockers/springs/etc. I say this with some hesitation though. I've never tried it. I considered it, but saw it as a potentially very expensive modification that reaslitically would only make my bike even more high strung and less streetable than it currently is. Also, if any of my research is wrong... Well, then I'd have a bomb spinning at 14,000 rpm in the head of my motor. Basically I chickened out and wasn't willing to take the risk until i had more exact measurements. |
November 2nd, 2013, 10:58 PM | #5 | |
May 20th, 2014, 11:49 AM | #6 | |
Join Date: Nov 2012 Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000 Posts: 327
Guys please excuse the whole thread necrophilia thing I've got going on here...
Per mrcycles, the 89 part number is 49118-1055, the part number seems to be the same until 1993 when it becomes 49118-1054. Would I expect to see any marking on the cam to indicate the different part numbers? I'll look anyway, and try to report the results.
Oh god the bikes are multiplying!!! |
adjustable camshaft timing how to. | Racer x | 2008 - 2012 Ninja 250R Tech Talk | 84 | July 17th, 2016 04:29 PM |
Camshaft Issue | jpatt87 | 2008 - 2012 Ninja 250R Tech Talk | 42 | March 25th, 2014 02:49 PM |
camshaft profiles | micoulisninja | 2008 - 2012 Ninja 250R Tech Talk | 30 | February 12th, 2014 04:01 AM |
Camshaft Chain Inspection | indr | 2008 - 2012 Ninja 250R Tech Talk | 18 | February 2nd, 2013 08:29 PM |
Intake Camshaft | jpatt87 | Items Wanted | 14 | January 19th, 2012 08:55 AM |
