November 3rd, 2013, 05:24 PM | #1 |
Aurodox's Ninja 300 Lighting Upgrade Thread
Hey all! I've decided as a project to upgrade all the lights on the Ninja 300.There are 10 lights that need replacing:
Here's what I have planned:
This thread is where I'll track my progress. I plan to post video tutorials on how to install the lights in case any of you so desire. I'll also post pictures comparing the OEM halogens to the LED replacements. I also plan to link the bulbs that I use so that we can keep a database of the LED equivalents to the Halogen OEM bulbs,unless there is a rule about posting links to outside sites. Hopefully this thread will prove to be helpful to a few members. I should receive my first order of lights by the end of the week, so stay tuned! |
November 3rd, 2013, 10:20 PM | #2 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
November 3rd, 2013, 11:53 PM | #3 |
Join Date: Feb 2013 Motorcycle(s): 2014 Ninja 300 ABS, 2013 Ninja 300 ABS (RIP), 2015 FZ-09 (sold) Posts: 78
Looking forward to this thread
November 4th, 2013, 02:04 AM | #4 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
What are city lights? This is what I find if I google "city lights ninja"
I can not be a true player by playing around. |
November 4th, 2013, 02:30 AM | #5 |
November 4th, 2013, 07:09 AM | #6 |
Bkmoto is pretty good with lights
November 6th, 2013, 12:53 AM | #7 |
UPDATE:
So these LEDs that I bought for the turn signals arrived today. They don't fit the turn signal housing, although you can screw the cover closed with them installed. The cover pushes the bulb further into the assembly than it naturally wants to go. The LED bulb is not nearly as bright as the halogen, though the light does look cleaner. LED vs. OEM As you can see, the OEM on the right side is brighter than the LED on the left. I doubt that an LED bulb the same size as the halogen bulb will be able to fully match the output of a halogen, but we shall see. Speaking of LEDs the same size as a halogen, I did manage to find another Amber LED bulb that uses fewer, but more powerful LEDs and is the same size as the OEM bulb. I will be ordering a couple of these to test in the near future. I think those LEDs may work better than the ones I have currently because it will be sending out the light at nearly the same position in the reflectors as the OEM bulbs. That should, in theory, make the bulb reflect more light back to you making the turn signal look brighter. Also, the fact that it's nearly the same size as OEM means there will be no issues fitting the bulb in the turn signal housing. More lights are still to arrive. |
November 6th, 2013, 04:33 PM | #8 |
Can't wait to see the new new bulbs don't crack nothin jammin things in holes they don't fit properly in... Reminds me of a song... Ladies and gentlemen (not mr Conway Twitty )
November 7th, 2013, 05:23 PM | #9 |
This should be helpful for some folks. A couple of weeks ago, I ordered some replacement H7 headlight bulbs. Ultimately, I want to go HID, but figured brighter halogens at the moment would be safer. I have a video of the process of replacing the headlight as well as a video comparing between the two headlights while in use on the road.
I replaced the factory bulbs with Philips CrystalVision Ultra bulbs. How to replace the headlight bulb on the Ninja 300:
Link to original page on YouTube. Last futzed with by Aurodox; November 8th, 2013 at 12:53 AM. |
November 9th, 2013, 03:10 PM | #10 |
Update:
Received and installed the license plate LED (Found Here). It looks WAYY cleaner than the halogen. Easiest mod you'll ever do on the 300. You can buy any LED you want, just make sure that it is a T10 base and that it will fit with the light cover installed on the bike. Video: |
November 10th, 2013, 12:08 PM | #11 |
I like your new headlights, way brighter the bk moto setup has me thinkin though
November 14th, 2013, 12:26 AM | #12 |
Brake LED w/ Modulator
I got around to installing the brake light LED and the modulator. All in all, the job took me about an hour and a half. I was busy making a tutorial and making mistakes.
I'm sure some of you will find this useful! The video is kind of long, but if you watch the whole thing, I guarantee you will know exactly how to do this mod.
Link to original page on YouTube. |
January 8th, 2014, 11:36 PM | #13 |
You should do a comparison between your stock lights vs your new HIDs.
December 27th, 2014, 08:57 AM | #14 |
MOTM - Sep '14
I had a problem getting the clip off the head light bulb. Your video does not show how the clip works.
I found this.
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
tfkrocks' Ninja 300 Rebuild Thread | tfkrocks | 2013 - 2017 Ninja 300 General Discussion | 350 | February 25th, 2022 10:35 PM |
Ninja 250 & 300 Valve Spring Thread | garth285 | 2008 - 2012 Ninja 250R Tech Talk | 30 | February 19th, 2017 02:42 AM |
Ninja 300 vs. CBR500R - the inevitable comparison thread | adouglas | 2013 - 2017 Ninja 300 General Discussion | 180 | October 8th, 2013 01:53 AM |
Official 2013 Ninja 300 (and 250) Thread | 2009zx6rider | 2013 - 2017 Ninja 300 General Discussion | 1795 | January 2nd, 2013 01:07 AM |
Upgrade itch to new 300 | kcaja1 | 2013 - 2017 Ninja 300 General Discussion | 3 | September 14th, 2012 12:57 PM |
