February 15th, 2014, 11:11 AM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Where to buy brake piston rebuild kit?
So I am getting an annoying scratching sound at low speed coming from my front wheel. I changed the brakes recently but that didn't fix the issue. I am thinking the pistons need to be cleaned or may not be retracting all the way back. Should I replace the seals as well after cleaning and if so what's a good rebuild kit?
Last futzed with by agentbad; February 17th, 2014 at 12:00 PM. |
February 18th, 2014, 04:40 PM | #2 |
Get a sharpie or dry erase marker and draw a perpendicular line on the rotor on both sides. Then push the bike forward a few feet without hitting the brake. If the line gets erased, then its rubbing. I don't think your problem is the brakes unless you can feel them hitting.
Could be your wheel bearings though. Try putting it on the center stand and push down on the rear which will cause the front tire to come off the ground a little bit. Then have someone else spin the tire by hand. You might be able to diagnose it like that. Just be careful you don't knock it off the stand though.
February 18th, 2014, 08:13 PM | #3 |
I'll give both of those a try. I don't think it's the wheel bearing because it only has about 8600 miles on it. I gave it a listen with the engine off today just rolling with clutch in and I am pretty sure it's the disc.
February 26th, 2014, 09:27 AM | #4 |
Murph's has good kits for pregens: http://www.murphskits.com/catalog/index.php?cPath=180
Have you replaced the brake fluid or bled the brakes recently? Overfilling the reservoir can also have the effect of applying or locking up the brakes. |
February 26th, 2014, 01:42 PM | #5 | |
4 Piston Brake Caliper Adapter Bracket Upgrade | SV Racing Parts | Motorcycle-related | 30 | February 17th, 2022 05:59 PM |
282cc Piston Kit Questions | fordendk | 2008 - 2012 Ninja 250R Tech Talk | 22 | April 8th, 2013 06:43 AM |
277 Kit/high Compression piston | jasle | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 30th, 2012 08:20 PM |
Front brake master cylinder piston size | old3 | General Motorcycling Discussion | 3 | November 16th, 2012 03:39 PM |
Where to buy Piston Rings? | iceman.kcmo | 1986 - 2007 Ninja 250R Tech Talk | 5 | January 28th, 2010 11:59 AM |
